2012 4-Matic with S63 AMG style reps fitted.
Old Jul 17, 2012 | 06:00 PM
det550's Avatar
2010 E550
At least I think these are styled after an optional wheel on the S-Class AMG cars.
We finally got these fitted today. Really happy with how these turned out. Do not buy these wheels and expect them to fit. The front's will require you to run a really small 2-3mm spacer to clear the caliper. Otherwise I think these really suit the car well. I'll get better pics when it's not 100 outside.
Old Jul 17, 2012 | 06:09 PM
BarrettF77's Avatar
Looking at CLS 550
Looks nice. What are your thoughts on the 4Matic? Any issues or things to consider now that you have owned it with all wheel drive?
Old Jul 17, 2012 | 06:13 PM
det550's Avatar
2010 E550
Thanks, It's not even my car, it's my pops. He just came to me asking about aftermarket wheels because he didn't like the stock wheels. I've been modding cars for years so I jumped at the chance to figure wheels for him.
He's only had it 2 weeks now so he hasn't said much about the 4-Matic over his old RWD E550.
Every time I drive it I just focus on hearing the turbos spool up, I gotta stop doing that haha so I'm no use yet. I'll ask him after he's driven a few more miles in it.
Old Jul 17, 2012 | 09:25 PM
htn75's Avatar
11 E550, 05 NSX, 12 QX56, 93 Z32 TT, 12 CLS550
I think it looks perfect. Excellent Job!
Care to share where you got the wheels from? I may need to change mine up.
Old Jul 17, 2012 | 10:48 PM
vdubpower's Avatar
i drive them all, fast and hard
staggered set up, tire sizes???
Old Jul 18, 2012 | 08:47 AM
N91K's Avatar
GLK350, G55, AMG GTS, C63 507
Very nice!
Old Jul 18, 2012 | 11:38 AM
det550's Avatar
2010 E550
I got them from USARIM.com
Tire and wheel are stock size 19x8.5 and 19x9.5 Offsets are a little more aggressive 30 and 35.
Like I said before the fronts will not fit without a spacer.
Old Jul 19, 2012 | 06:47 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Works pretty well I think, but IMO a flatter/cleaner wheel on the CLS's heavily sculpted design would be ideal.
Old Jul 19, 2012 | 05:15 PM
Wgs2052's Avatar
Currently Own: `12 CLS550 4Matic & `12 GL450 Previously owned: `10 E350 4Matic & `10 ML350 4Matic
Det550...was following your other post and glad to see you go the wheels on. Look great. Very nicely done.
Following up on the question Vdubpower had on your wheel setup, I wanted to get a bit more information from you. I also have a 2012 CLS 4Matic but do already have the +1 optional 19in AMG style wheels on the car. I going to be installing spacers as well to provide a more aggressive offset like you did. Want to know:
1. What brand of spacers did you use (H&R Trak+, or other)
2. What size did you order for the front and rear to get to your 30mm & 35mm offset end state (was it a 3mm in the front and 15mm for the back?)
3. Post install, have you had any issues with vibration or other?
Looks like your running stock 19" in sizes on both wheel width and tire size on your rep wheels as my OEM 19"s, so setup with spacers could be replicated on my vehicle.
Appreciate your insight. My vehicle pick below...
Old Jul 19, 2012 | 06:34 PM
vdubpower's Avatar
is the amg 19inch set up a staggered setup from factory??? for the 4 matic
Old Jul 19, 2012 | 07:01 PM
Wgs2052's Avatar
yes. they are the staggered setup
Old Jul 21, 2012 | 03:08 PM
det550's Avatar
2010 E550
The wheels we're running are actually made in a 30 and 35 offset. That is typical for aftermarket wheels this size so spacers were not used to achieve the more flush look in this instance.
I'm 99.9% positive the offsets for your factory 19 inch wheel set up is as follows.
Fronts
19 x 8.5 eta 34.5
Rears
19 x 9.5 eta 48
So basically if you wanted to achieve the same look with spacers on your factory 19"s you would need a 4.5 spacer in the front, and a 13 mm spacer in the rear.
There is room to move them out a bit more in order to get spacers in the normal size offered. I think if you went with a 5mm front and anywhere from 13-15mm in the rear you would be fine.
I don't have much expierence running spacers I usually don't care for them but I know from previous exp on other cars that H&R makes a good product.
Since this car is so new I would recommend giving a good H&R track+ distributor a call to get the best information. I just wanted to help you out with what I know to be the factory offsets for the wheels you are running.
