New CLS owner needing help
Hi everyone, just a quick question, I have taken delivery of a 2012 CLS, but I have a slight problem. Once my car goes into reverse, I don't know how to make Drivers door mirror dim automatically.
Would anyone know how to fix this, it is bugging me!
thanks
O
thanks
O
2013 CLS250 CDI
Hi, nice to see someone else with a CLS250. I have only just got mine 2 days ago and have not noticed if it does it or not. I will have a look.
UPDATE: mine does not dip and I cannot find a setting so looks like it does not have this feature. Surprising.
15 cls 550
you need to have the side-to-side mirror switch on the armrest set to the passenger side. It won't work if it's set to the driver's side. I just leave mine set to passenger unless I need to adjust the driver's mirror. Then, it works fine. (Mine's a '12)
2013 CLS250 CDI
Just tried that and does not seem to work, I have a 13. Also with reversing camera if that makes a difference.
15 cls 550
If you haven't already done so, suggest you save the dipped setting you like in memory. I seem to remember the car didn't come with a dip setting per-programmed as they used to.
Mine has the camera.
I don't have the memory function, however, the car does come with the auto dimming feature. It's still not working for myself. Just curious, as it worked on my previous E class (2011).
I dip the mirror when in reverse, then I just manually to it back to eye level.
Not entirely sure, if anyone can suggest anything else. Much appreciated.
Cheers
Cheers
