Kleeman dyno on 2012
Old Aug 19, 2014 | 09:02 PM
LivEviL's Avatar
2012 CLS550, 2005 Grand Cherokee, 2006 Wrangler
Stopped by a shop and had a dyno run today. About right on from what they say it should be. Slight concern on AFR though. Thoughts? Sorry for the crappy YouTube, but I had to shoot it from 30 feet.
Dyno 2012 Mercedes CLS550:
Old Aug 21, 2014 | 01:56 PM
Jeffy's Avatar
2014 CLS550 4Matic
Are they correcting for powertrain loss and reporting 433hp at the engine? Or do you have this car modified? For a stock car should be around 375-390hp at the wheels.
Old Aug 21, 2014 | 02:02 PM
LivEviL's Avatar
It is calculated at the wheels and is not adjusted. 433hp and about 525tq. Only mods are the resonator is removed and Kleeman tuned the computer. So with a 15% loss added back, it would be 509HP and 617tq.
Old Aug 21, 2014 | 11:27 PM
C63newdude's Avatar
C63 AMG
What are your concerns on the AFR?. did they use a wide band during the pulls? As far is your dyno output numbers, I think that you are spot on with other tuners like Dyno-comp which got 443whp/520lb-tq on a Dyno Dynamic dyno: see link below
http://www.dynocomp.com/details.php?...90#detail_1191
Old Aug 21, 2014 | 11:35 PM
C63newdude's Avatar
C63 AMG
did you ran a baseline dyno pull?
Old Aug 22, 2014 | 10:55 AM
LivEviL's Avatar
I did not do a baseline. AFR was measured with a wide band in the exhaust. I am happy with the results, as they are slightly better than Kleeman advertised. I thought the AFR's should not be over 12-12.5 at full throttle.
Old Aug 22, 2014 | 05:54 PM
Jeffy's Avatar
2014 CLS550 4Matic
Nice! Congrats.
