CLS w218 upgrade
Old Mar 2, 2016 | 05:08 AM
Fabby's Avatar
Mercedes CLS
CLS w218 upgrade
Hi I have a CLS w218 2013 can I change the front and back bumper with the new version CLS 2014 facelift? does it fit?
Old Mar 3, 2016 | 03:00 AM
sambam2006's Avatar
GLC Coupe, S63L W222
From my knowledge and sources the LED headlights are the same size, no change in measurements or size, the new lights will be a straight swap BUT the wiring and control box to the new headlights is different.
The front and back bumpers have the same fittings with no difference in measurements or size when it comes to fitting them, so straight swap BUT... Beware though the pre facelift CLS has the led day time lights which require modification to fit onto the new bumper if you decide to keep the old headlights. The new headlights have the day time lights built into them.
Hope this helps (I know someone who has done this btw)
Old Mar 3, 2016 | 04:25 AM
Fabby's Avatar
Mercedes CLS
so in conclusion i need to chage: front bumper,grill,lights and the back bumper
thanks for you info. you don't know by any chance the part numbers for the facelift version?
Old Mar 3, 2016 | 12:51 PM
RacingFish's Avatar
CLS550, 57’ Chevy Nomad, Subaru LGT wagon
Try contacting a body shop that specializes in mercs
Old Jun 28, 2016 | 05:55 PM
Sad4619's Avatar
CLS550
Do you know anything about swapping a 2012 cls550 grille for a 2015 diamond grille ?
Old Nov 13, 2017 | 12:35 PM
delirium's Avatar
C350
I'd like to know the same, specifically for a 2012 CLS63
Old Nov 14, 2017 | 12:09 AM
MBmemphis's Avatar
2013 CLS550
I don't think you can simply exchange the grills, you would have to swap the entire bumper. I have seen an aftermarket diamond grill that would fit into the 2012-2014 CLS but I am suspicious to the quality of it as I have not seen it in person (I think it is fairly hard to switch them out as well)
Old Nov 14, 2017 | 12:15 PM
Gee_115's Avatar
CLS550, BMW 550, Tesla Model X P100D
I saw a 2012 being sold and it had the diamond grille with the 2012 bumper. I believe it can be done.
Old Nov 14, 2017 | 02:48 PM
pacificmotors's Avatar
Former Vendor of MBWorld
None. We dismantle them :)
The front and rear bumper is interchangeable from 2012-2014. The lights may get a little tricky, depending on if you have HID or LED. It appears they will also interchange 2012-2014 as well, but it's certainly possible the wiring may be different. I wish we had the 2014 parts in stock your looking for so I could give you more exact information, but we only have the 2012 parts in stock at the moment.
Send us a PM if you have any questions!
Old Nov 14, 2017 | 06:41 PM
Gee_115's Avatar
We kinda know that. I think you misunderstand, we are trying to find out if the facelift 2015+ bumper, grille and headlights can be interchanged with 12-14...or maybe I'm the one who misunderstands.
Old Nov 18, 2017 | 02:49 AM
mrsoandso's Avatar
CLS550
I found this on alixpress, it's a huge gamble because chinese quality is always hit and miss.
https://www.aliexpress.com/store/pro...807326748.html
Old Nov 22, 2017 | 03:51 PM
Gee_115's Avatar
A bit pricey as well.
Old Nov 22, 2017 | 04:20 PM
Gee_115's Avatar
Also found this on ebay.
https://www.ebay.com/itm/MERCEDES-CL...19.m1438.l2649
Old Nov 22, 2017 | 07:27 PM
MBmemphis's Avatar
2013 CLS550
I have seen that on eBay as well; I question the quality and the fact that the bumper has to be taken off to install; seem like that alone would be a couple hundred so then you are 500-600 in the hole. That's a fair amount of money
Old Nov 28, 2017 | 02:33 PM
Gee_115's Avatar
Apparently someone has done the upgrade. Some good info about the LED fogs.
https://mbworld.org/forums/w218/5522...-done-yet.html
Old Nov 29, 2017 | 12:11 AM
MBmemphis's Avatar
2013 CLS550
i have looked for that thread before....now I want to price a new front bumper out : /
Old Dec 6, 2017 | 10:39 AM
Gee_115's Avatar
I forgot that I had saved a pic of that 2012 with the Diamond grille I saw for sale. I believe it was either out of Florida or Texas. I think I'm gonna shoot for the whole face lift bumper and grille.
Old May 10, 2018 | 08:17 PM
A330PYLT's Avatar
2016 CLS550 4matic
My car is a 2016 and I can tell my bumper is slightly different but I believe the dimensions for the grill would be the same. The Headlights would be the tell tell for me. I think they changed the design in 2015
Old May 10, 2018 | 09:27 PM
Gee_115's Avatar
Actually, 2015s had both headlights. The Grille is totally different, the 12-14 will not fit 2015+ or vice versa.The bumper however is a direct fit, you'll have to figure what to do with the DRL strip. I have the bumper but the grille and trim pieces have been incredibly hard to source reasonably.
Old Jul 18, 2018 | 02:10 AM
aguilar6222's Avatar
CLS400
Does anyone know if I can swap my 2015 headlights for the 2016?
Old Jul 18, 2018 | 04:00 AM
mercteil's Avatar
G Wagon
Yes, you can. You will also need front FL SAM and coding.
We may offer headlights and SAM, please PM your VIN and ZIP to check costs. Thank you.
Old Jan 22, 2019 | 04:43 PM
318southernboi's Avatar
2013 cls 550 with the facelift!
i sourced out all parts for the face lift and the total was $700 shipped to the door... it’s incredibly hard to source out each piece from different websites, also nobody carries the cls facelift versions.. so mbvehicleparts is a good place to start
Old Jan 22, 2019 | 11:42 PM
CLS400
so I just recieved notification that you responded to my question.. 6 MONTHS AGO. Thank you
I'm unable to PM you the info. Are you still available to source the parts I need?
Old Jan 23, 2019 | 04:25 PM
plamax's Avatar
2014 MB Cls 550
Here it is. Said and done ;) Full facelift upgrade of 2014 CLS 550.
Old Feb 1, 2019 | 08:01 PM
Goatk1's Avatar
W218 CLS 400
Is that full AMG mufflers or just exhaust tips? Pls explain!
