DIY help needed on Spark plug replacement
Old Jun 4, 2016 | 06:33 AM
wlee69's Avatar
'13 CLS550, '17 Q7, '11 G550
For those that have replaced their plugs (I'm running a Renntech ECU upgrade and have read that the newer OEM sparkplug are better) is there any trick to getting the electrical connector disconnected at the top of the igniter coil??
I release a grey lock at the top by sliding it out, but then it seems like the whole harness should just unplug, but I'm pulling relatively hard it it doesn't move? Trying to be careful not to break/crack the plastic connector.
Thx in advance,Will
Old Jun 4, 2016 | 08:20 AM
Swoosht04's Avatar
11' E350, 11' G37 Sedan, 13' ES350
Hope this helps. Some of the links for the Pics seem to be dead but the info is there.
Good Luck.
https://mbworld.org/forums/cls-coupe...273-960-a.html
Old Jun 4, 2016 | 11:27 AM
konigstiger's Avatar
'71 Pinto
OEM Part # + plug indexing attachment.
Old Jun 4, 2016 | 12:31 PM
wlee69's Avatar
Good Luck.
The newer c218 has different coil packs, but thanks for the link. Seems like it should just work the same way to get them off!!!
Old Jun 4, 2016 | 12:32 PM
wlee69's Avatar
Thanks for the info. The new part# was what I ended up ordering so I just need to now install them (and check the gap first!!)
