New Owner, have some questions!
Old Aug 7, 2016 | 09:10 PM
MBZCLS5504MATIC's Avatar
2013 CLS550 4MATIC
Hi All. Just got a 2013 CLS550 4Matic. I am absolutely IN LOVE with my new car. It's everything I wanted but I have a few questions, hoping you guys can help.
I have navigation with backup camera, but the camera doesn't show those helpful green and red lines on the screen to guide me in parking. I know the 2014 model however does have these lines. Is there anyway for me to switch out any modules or upgrade my system to have this feature?
Old Aug 10, 2016 | 01:22 AM
2013 CLS550 4MATIC
Old Aug 10, 2016 | 01:48 AM
TTMerc's Avatar
2014 CLS63 S
Yeah you'll get a lot of that here! Welcome and congrats on the car! Youll get a lot silent treatment here! As far as I have read if you have the larger screen on your command you should be able to re code it!
Old Aug 10, 2016 | 03:16 AM
2013 CLS550 4MATIC
How does one go about re-coding it? I'll literally do anything to have this feature!
Old Aug 10, 2016 | 10:15 AM
TTMerc's Avatar
2014 CLS63 S
See what version your command is and then see if there's an update for it would be the first thing. If that doesn't give you that then google your little heart out lol. Command will be the same across multiple cars so doesn't have to just be for cls. If the option isn't in the Engineering menu then it would have to be an added option (option code) with a Mercedes STAR system if possible. A lot of European youtubes do things like this if it's possible. I'll do some searching as well
Old Aug 11, 2016 | 05:16 PM
2013 CLS550 4MATIC
What am I looking for exactly in the engineering menu? I saw some things last time I Checked, but there's no clear "On" or "Off" type scenario.
Old Aug 11, 2016 | 06:03 PM
PaulE550's Avatar
2015 E550 Coupe
OP,
There are a few threads on this forum that discussed this very topic. If you read through them, you'll see that there apparently isn't any easy upgrade to provide you with this functionality. At least from MB anyway. Some folks have resorted to pulling out the command unit and putting in third-party solutions. I don't know if that's a path you want to pursue, but apparently that is an option.
You should of course check with your local MB dealership service department to see if a software / firmware update to your command unit has been released by MB since the last posts on this topic. The movable lines you see when the rear view camera is active are from a senor in the steering wheel tracking the rotation of the wheel. So you would also have to verify that the model year car you have has this necessary steering wheel sensor in place as well. Otherwise, any command unit software update won't do you much good. Again, either something that a more knowledgeable member of this forum can verify for you or something that a MB service department can tell you.
Hopefully this helps a bit.
Old Aug 11, 2016 | 07:50 PM
emericr's Avatar
2021 Porsche TTS
Like others have said, there is unfortunately no easy retrofit for it. I looked into it when I bought my 2013CLS63. Sorry.
As a side note I have a comfort box and KW coilovers to sell if you are interested.
