Need opinions/advice on this 2012 CLS550 - thinking of buying
2012 CLS550
Has the interior colors I like along with the sport steering wheel. The wheels are OK but I'll change them out.
What do you guys think? I'm in AZ but would fly to LA then drive it back. Anything I should look for? Carfax looks clean and has low miles for 2012.
Any feedback would be greatly appreciated.
sorry about the link...should be working now. Thanks for the advice.
Other than that....pare5 hit it on the head. The 278 is fantastic...just follow his/her recommendations about checking the timing chain, tensioners and valves.
As a side note....they also have a CLS63 for about 10k more. Yeah it has more miles (45k)...but it's a bigger starting point (depending on what you want to ultimately do). A 550 with a tune will have as much HP as a 63, but a 63 with a tune will get you over 650HP alone.
That being said... I've never bought a 63, so I have no room to talk
Clearly I'm going to listen how it starts and runs, but are there some simple tests I can do - like a compression test?
Are there other things to note? I think there will be quite a few water damaged cars showing up soon, casualties from Harvey and Irma...
