Dreaded AC Smell :(
Old Oct 11, 2017 | 02:12 AM
Pekkle's Avatar
2007 E550 Sports
Dreaded AC Smell :(
Hello Guys,
I have the famous Mercedes AC smell... It started as faint cow poop smell only when I turn on the AC for the first 20-30 seconds... However now it has become a constant smell when the AC is on. I searched and searched, most people says the smell is coming from the AC Evaporator, and I saw one guy on Youtube spraying Koolit inside the Cabin Filter housing to rid off the smell. Is this a safe approach to clean the evaporator? Second, I never seen any water from under the car when the AC is on, so I am assuming the AC drain is plugged. Is there a way to find the drain plug? How do I unplug it?
Old Oct 11, 2017 | 10:58 AM
TNTim's Avatar
2012 CLS 550 Launch Edition
I have the bad smell coming from mine and have heard that the Kool-It approach is the way to go. I've just ordered some so will let you know how it goes when I do it this weekend.
Old Oct 13, 2017 | 02:38 PM
Pekkle's Avatar
2007 E550 Sports
Sounds good! I am also getting mine Kool-It from Amazon today along with Activated Carbon Cabin Filter. So I will share my result back as well. Good luck to both of us!
Old Oct 15, 2017 | 01:58 AM
TTMBCLS's Avatar
cls550
the best way to clean the air.. is remove the cabin filter and place the spray into the dash board and spray.
Old Nov 12, 2017 | 11:17 PM
SpeedRacerX's Avatar
2012 CLS550 4Matic
I had the smell also on startup for about 20-30 seconds. I changed my cabin air filter and it went away.
Old Nov 16, 2017 | 09:11 PM
scyrozyk23's Avatar
2012 e550
use Klima Cleaner. I did on few cars and works wonders.
