AIRmatic Suspention help!!!
Old Jan 3, 2018 | 07:52 PM
skooter753's Avatar
08 CLS 550
So..... Came home after a 5 day trip. The driver side of my CLS550 is dropped to the ground. I get the "STOP VEHICLE TOO LOW" warning. Start the car, nothing. I bring the car in the garage and turn on the propane heater (it's been -3 degrees in Cincinnati), leave it overnight, try again.... nothing. So today I replaced the 40AMP fuse and the relay. The vehicle too low message is gone but now it says "Malfunction". I cannot hear the air compressor running at all. So should my next step be to replace the compressor? Any help would be greatly appreciated.
Old Jan 3, 2018 | 08:11 PM
skooter753's Avatar
08 CLS 550
UPDATE.... So minutes before I pulled the trigger on a new compressor, I went out to the garage and decided to try again (garage temp was about 45 degrees F.) Turn the key, and I hear the sweet sound of the compressor kicking on. The car rises. Not sure if there was water in the lines or what. I will check in the morning to see if the car remains at the correct height.
