Hi folks, just bought my 2012 CLS 550 yesterday and I'm super stoked, bought these 20" OEM AMG rims on ebay: https://www.ebay.com/itm/272902928883?ul_noapp=true
the specs are:Name:
AMG
Color:
Powder Black
Front Size:
20x8.5
Rear Size:
20x9.5
Offset:
Front: 35
Rear: 35
Factory Spec
Bolt Pattern:
5x112mm
Condition:
Brand New
Quantity:
4
Hub Bore:
66.6mm
Part Number:
Front A2224011200 Rear A2224011300
Any ideas what tires to use? Are these ok wheels to use?
Thanks!
the specs are:Name:
AMG
Color:
Powder Black
Front Size:
20x8.5
Rear Size:
20x9.5
Offset:
Front: 35
Rear: 35
Factory Spec
Bolt Pattern:
5x112mm
Condition:
Brand New
Quantity:
4
Hub Bore:
66.6mm
Part Number:
Thanks!
Why did you buy wheels for CL-Class? The ET won’t match. If you insist on putting them on, try to get within 3% of original tyre dimension.
Thanks, Jan.
The sellers said it would fit perfectly for cls550. Will they not work?
When I purchased aftermarket 20” wheels the recommended offsets were 25 front and 33 rear for 9” and 10” respectively and that makes them pretty flush with the fenders. My Stock 19” wheels where 8.5 with offsets of 35 on the front and 48 on 9.5” wheels on the rear which sat too far inboard for my liking So, my guess is that your front will sit similar to stock, which in my opinion will need spacers to bring them out a bit. And the rear should probably look good as they will come out 13mm from stock.
Tires are tricky on the front if you have airmatic as the bag boot limits tire/wheel height like on my 2016. Stock overall height/diameter is 26”. I got away with 26.8” on the front to get a slightly higher sidewall for better ride but I have less offset which may have helped. From what I understand, that’s about the limit and it depends on tire choice as not all tires are to spec. Don’t try 27” overall height.
Stock diameter tires are then 255/30-20 on front and 295/25-20 rear or similar. But I found these sizes limited my choice considerably as they are not very common and are lower profile sidewalls than I would prefer. So I opted for 245/35 and 285/30 which are slightly taller but on my wheels work ok - clear the boot on the front. You might find this works ok on your setup as well, but you may want or need to consider adding a 10mm? (not sure exactly what size to be honest) spacer to the front. It will likely look better and help with clearing the boot.
If your suspension is different than my 2016 setup, I can’t really help.
I have bought aftermarket OZ for my previous CLS63 and the ET was 35 instead of 37 so that was negligible. OZ use a centering hub/ring which gave me a bit of trouble, it made the wheels shimmy a bit when it was not positioned according to the wheel shop mark (MB dealer put the wheels on once without knowing this).
I also try to avoid using spacers for a similar reason.
Add potential rubbing issues and you are spending time and money which is not necessary if you have original rims.
Check willtheyfit.com to calculate the right sizes.
I’d return the wheels and buy original CLS though.
I don’t think that’s necessary at all. They most likely will fit just fine with the right tires. Hub-centric spacers from H&R on the front will maybe make them look even better. Most stock wheels are inset too far and are all too common to give it a nice look. I’ve never owned a car more than a few weeks before changing wheels. It’s the easiest and often most impactful mod you can make to a car. Originally Posted by Jan AMG
When I asked the Seller about these wheels, this is the reply I got. Can you guys make heads or tails of this?
The offsets are not off and actually factory sizes. Not sure where you are getting information but its absolutely incorrect. I am the AMG rep in Eastern US and have been mounting these on that model since 2015. The information is below and in the Mercedes dealer and parts book. Thanks, John Simon, VP AMG.
2011, 2012, 2013, 2014, 2015 2016, 2017
CLS550 Bolt Pattern
PCD 5x112
Stock wheel offset
36 to 50 mm
Center bore (hub bore)
66.6
Thread size
M14 x 1.5
Stock Rim Sizes Range
18x8.5 – 20x10.0
Tire sizes
255/40 R18 – 255/30 R20
CLS550 Bolt Pattern
PCD 5x112
Stock wheel offset
36 to 50 mm
66.6
Thread size
M14 x 1.5
18x8.5 – 20x10.0
Tire sizes
ExploreMBWorld Fanatic!
Interesting.
There were no original 20” wheels for CLS I know of nor they were in the configurator.
Stock sizes were 17”-19”.
I did a quick google for the rear part number and it seems these are a stock wheel option on the w222 S-Coupe.
https://www.mercedes-benz.com.au/pas...ccessories.pdf
They are noted in this brochure as having ET 38 with much taller tire sizes than will fit on a CLS with airmatic. If the seller has been installing these on a CLS it would be interesting to know what tire sizes he’s been using because the stock front size in that brochure is a 245/40-20 which has a diameter of 27.7” which will not fit on a CLS like mine. Not sure about the 2012.
Of course, you can use a lower profile tire, as per my recommendations above, and I think you will definitely want a 10mm spacer on the front as ET38 is going to look like the wheel is too far inboard, in my opinion.
The wheels you purchased are perfectly fine. ET 35 for both will fit without any issues. Use 255/30/20 Front and 295/25/20 Rear. These are ideal for CLS550. You can also try 245/35/20 front and 285/30/20 Rear. The suspension boot in the front is a little bit different for every car so the 245/35/20 series might fit or it might not. You will have to try. But the first option will fit without any problems. CLS 550 ET range is anywhere between 20 to 37 and rear is anywhere around 30 to 45, so don't worry about the ET.
Quote:
I have a simular question, i have a 2007 CLS 550 and am trying to find out if a 20x9.5 wheel will fit up front? If so, what offset and tire size would be best. Any help is appreciated. Originally Posted by Acidic Reflux
Good evening gents...
I have a 2016 S550 4Matic with 245/45/19 Front and 275/40/19 Rear. Can i run 265/40/19 in the front to match height "40" in rear, or will that tire be too wide for the 8x5 front wheel and will it cause tranny or differential issues? Hate looking at the taller size tire up front!!!!!
Will dimension fit within the 3% rule
