2012 cls550 command won't turn on
Old May 18, 2018 | 07:59 PM
aj jain's Avatar
2012 cls550
Hi all,
a few weeks back my rotating knob stopped working, but rest of command was fine. Earlier in the week it hit 100 inside the car (not too bad) but the screen stopped working. All functionality still works (music, bluetooth) but pure black screen.
any advice??
Old Jun 5, 2022 | 09:26 PM
MadOvaHollywood's Avatar
2014 CLS 550
Originally Posted by aj jain
Hi all,
any advice??
I have a 2014 CLS 550 and having the same problem, everything works but the screen won’t turn up, I check the fuse even replace the screen and nothing still, did you figure it out????
Old Jun 6, 2022 | 10:41 AM
konigstiger's Avatar
'71 Pinto
ECO battery in trunk may need replacement if fine, have someone pull/erase codes (battery relay could be failing) and check for COMAND CU (head unit) software update using Xentry (MB diagnostics).
File Type: pdf
