Ground strap location ??
Ground points location ??
Hello guys,
I just got a 2015 CLS400. I'm planning to install a new dash cam and hard wired it. I know there is a fuse box on the left hand side of the steering wheel where I could add in a circuit to power the dash cam.
However I haven't got around to look for the nearest ground ground bolt/points to ground the wire yet.
Can anybody tell me where it is?
thanks
thanks
I figured that out. The new CLS does not have fuse box in the driver hand side area, it only has one fuse box under the hood and the other in the trunk (accessories). So I use 2 add in circuit for dash cam and radar detector. Pretty straight forward and clean install. Most time consuming part is removing trunk floor mat and side cover.
