AutoTalent | Renntech Ecu + Brakes + Suspension for Mercedes-benz Cls63 2012-2018
Old Oct 17, 2019 | 05:59 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu 1!
Click HERE to order Performance Ecu 2!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech proprietary ECU+ upgrade for the Mercedes M157 engine offers huge gains in performance across the entire RPM range without sacrificing around town comfort or daily driver reliability. Our ECU tune offers the biggest performance gains on the market with our dyno results increasing performance from 556 HP and 544 lb/ft torque, up to an astonishing 669 HP and 734 lb/ft at the crank! This allows the CLS63 AMG to run the quarter mile on D.O.T. street tires in an impressive 11.3 seconds at 125 mph with 0-60 mph coming in a mere 3.4 seconds. Equipped with drag radials on the CLS we were able to achieve an even more impressive quarter mile time. The CLS was able to rocket down the drag strip; clocking a quarter mile time of 10.9 seconds @ 129 mph with 0-60 mph coming in 3.2 seconds!
Features
Gains up to +119HP / +190TQ
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Stock Performance
518 HP @ 5,500rpm; 520 LB-FT @ 2,000-4,500rpm
550 HP @ 5,500rpm; 544 LB-FT @2,800-3,900rpm
Modified Performance
669 HP @ 5,500rpm; 734 LB-FT @ 3,700rpm
Renntech Performance Package
Click HERE to order R1 Performance Package!
Click HERE to order R2 Performance Package!
Click HERE to order R3 Performance Package!
The RennTech R1 Performance Package is the perfect entry level performance upgrade for the E 63 AMG. With the combination of the RennTech ECU Upgrade and the latest, 3rd generation Diverter Valve RennTech is able to add up to 146 HP and 257 LB-FT to the 5.5L V8 BiTurbo engine (compared to RENNtech rated stock performance). The addition of the upgraded diverter valve helps the engine to handle boost spikes in high boost pressure applications better. A surplus of boost will be released to the atmosphere and the turbocharger can be supplied with air quicker after the shifting process. This helps to eliminate the 'Turbo Lag'. The R1 performance package increases performance up to 696 hp and 801 lb/ft at the crank, without sacrificing daily driver comfort or reliability and offer huge gains across the entire RPM range. Due to increased power and boost levels, 93 Octane or higher gasoline has to be used with R1 upgraded RennTech vehicles to avoid damage to the engine. States known for poor fuel quality have to be supplied with a lower power setup. The R2 performance package increases performance up to 716 hp and 826 lb-ft without sacrificing daily driver comfort or reliability and offer huge gains across the entire RPM range. The R3 performance package increases performance up to 790 hp and 895 lb-ft at the crank, without sacrificing daily driver comfort or reliability and offer huge gains across the entire RPM range.
Features
RennTech 3rd Gen. Diverter Valve
BMC High-Flow Air Filters
Stock Performance
696 HP @ 5,500rpm; 801 LB-FT @ 3,700rpm
716 HP @ 5,500rpm; 826 LB-FT @ 3,700rpm
790 HP @ 5,500rpm; 895 LB-FT @ 3,700rpm
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Software Upgrade!
Click HERE to order Performance Transmission Upgrade!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech 722.9 Seven speed Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. Our upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
Renntech Performance Diverter Valve
Click HERE to order Diverter Valve!
RennTech 3rd Generation Diverter Valve for the M157 5.5L V8 BiTurbo features an all-new Blow-Off Valve implemented into the re-designed OEM turbo tubes. The Diverter Valve releases the boost in high-boost situation and/or boost spikes. This especially helps during the shifting process, for faster shifting and a quicker boost response for the next gear. It helps to eliminated the so called 'Boost Lag'. With the installation of the RennTech Diverter Valve, they are able to supply the engine with more boost pressure in order to gain higher HP numbers. The turbo tubes are ceramic coated in titanium to sustain high temperature and provide a more aesthetic look in the engine bay
Features
Helps to eliminated the so called 'Boost Lag
Helps during the shifting process
A quicker boost response
Higher Horsepower
Faster shifting
Renntech Performance Carbon Fiber Airbox
Click HERE to order Carbon Fiber Airbox!
Click HERE to order Carbon Fiber Airbox with Turbo!
RennTech using the highest quality pre-preg carbon fiber, our 4-piece airbox kit for the 63 series biturbo M157 engine comes complete with flow optimized turbo tubes to maximize engine performance by increasing the volume of incoming airflow. The carbon fiber airbox was designed, engineered and manufactured in the USA using only industry-leading materials to ensure long lasting durability and appearance. RennTech carbon air box is able to offer gains up to +10 hp and + 10 lb/ft of torque, in addition to serving as an attractive under hood showpiece. The Carbon Fiber Air Box kit includes a Set of 2 BMC high performance air filter.
Features
High quality prepreg carbon fiber construction finished
Increasing the volume of incoming airflow
Comes complete with flow optimized turbo
Long lasting durability and appearance
RennTech 4-piece airbox kit
Gain +10 HP & +10 TQ
Stunning good looks
Design is perfect
Simple to install
Renntech Performance Aerodynamics Parts
Click HERE to order Carbon Fiber Front Splitter!
Click HERE to order Carbon Fiber Rear Diffuser!
Click HERE to order Carbon Fiber Deck Lid Spoiler!
RennTech front splitter was designed with your daily driver in mind and maintains the same approach angle as the OE front fascia so the RennTech front splitter retains the same clearance for parking stops, curbs and steep driveways. The high quality prepreg carbon fiber construction finished in a beautiful gloss top coat ensures years of durability and stunning good looks. RennTech rear diffuser specifically designed for the CLS 63 Biturbo is the companion component and perfect addition to our 3-piece carbon front splitter. It visually enhances the rear of the CLS, acts as a functional component of the vehicles exterior in order to decrease drag and increases rear down force. This is accomplished by improving the underbody airflow and allowing for a smooth transition to ambient air when the vehicle is at speed. RennTech full carbon fiber rear spoiler for the 218 CLS is the proverbial “cherry on top” and a stunning addition to the rear of the CLS exterior. Its unique design complements the refined trunk lines yet offers a more aggressive, stand-out look.
Features
Unique and aggressive aerodynamic package
Design is perfect as a stand alone component
Improves vehicle aesthetics
Beautiful gloss top coat
Simple to instal
Aggressive exterior enhancement
Renntech Ss Exhaust Sport Mufflers
Click HERE to order Ss Exhaust Sport Mufflers!
RennTech T-304 stainless steel (SS) sport mufflers are hand made and rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. RennTech mufflers with 2 3/4 inch diameter tubing offer lighter weight than the stock exhaust and improve performance by reducing exhaust back pressure, increasing exhaust gas flow and cylinder scavenging. The RennTech sport mufflers on the CLS 63 (C218) utilize the OEM tips and need to be modified to fit our sport mufflers and will require welding of OEM tips.
Features
Stainless steel (SS) sport mufflers
Hand made sport mufflers
Offer lighter weight
Improve performance
Reducing exhaust back pressure
Increasing exhaust gas flow
Gain up to 10 HP & 15 TQ
Stunning good looks
Design is perfect
Simple to install
Renntech Performance Toe Link Kit
Click HERE to order Toe Link Kit!
Adding a RennTech toe link kit maintains stability at high speed, ensures the vehicle tracks straight under heavy acceleration as well as properly positions the car's suspension under heavy cornering and braking loads. RennTech toe link kit also allows the possibility of fine adjustments to the suspension and of bump steering for additional stability and improved vehicle handling characteristics without negatively impacting ride quality and comfort
Features
Improved vehicle handling characteristics
Maintains stability at high speed
Provide ride quality and comfort
Improve performance
Stunning good looks
Design is perfect
Simple to install
Renntech Locking Limited Slip Differential
Click HERE to order LSD!
RennTech Locking Limited Slip Differential, a differential is the last point between the engine and the wheels where power is transferred. The differential functions as a system to direct engine power at the wheels while allowing them to rotate at different speeds. By upgrading the differential, you benefit in both straight line stability and vehicle handling while cornering. During a full power straight line run, our LSD (limited slip differential) will lock 100% and provide torque equally to each powered wheel, providing stable straight line runs. When exiting from a corner, our LSD's transition to the full 100% lock position is smooth and predictable. This gives the vehicle better traction and stability throughout the corner, improving overall lap times and a noticeable improvement in overall vehicle handling. The track is not the only place where the differential comes into play though. Bad weather and harsh road conditions can make the street a dangerous place. In snow, ice, wet weather and regions where the road surface can become unstable, our LSD easily adapts and adjusts tire rotation to increase vehicle stability on the road and help to dramatically improve driver safety. RennTech differential is a unique, patented, clutch- type LSD which makes this a true100% locking differential. Because of this function, there is no movement of internal parts, leading to less heat being generated while in operation and in turn, less wear of the friction disks.
Features
Provide torque equally to each powered wheel
Provide stable straight line runs
Gives the vehicle better traction
Stability throughout the corner
Improving overall lap times
Provide straight line stability
Increase vehicle stability on the road
Help to dramatically improve driver safety
Renntech Performance Brake Package 1
Click HERE to order Performance Brake Package 1!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
Deliver more consistent brake pedal feel
Reduce fade compared to stock
High-performance brake pads
Long-lasting reliability
Braided steel lines
Renntech Adjustable Suspension Kit
Click HERE to order Adjustable Suspension Kit!
Click HERE to order Adjustable Suspension Dlm Kit!
RennTech digital suspension lowering module (DLM) in place of the rear adjustable links.This allows the suspension system to remain balanced as the digital lowering module controls inputs to all four sensors on the vehicle (even though only the rear suspension is adjustable electronically). It also alllows for complete adjsutablility of rear ride height via the lowering module software (included) with no need to manually adjust links on the rear. RennTech feel that this combination best maintains the suspension system’s functional integrity as it accounts for the suspensions load leveling function, offers improved ride quality over the standard suspension kit with adjustable rear links and allows for complete electronic adjustability of rear vehicle ride height via the included software..
Features
Easy control of rear ride height via the digital lowering module software
Front suspension level is accounted and adjusted for lowered ride height
RennTech sport lowering springs for front axle
RennTech height adjustable spring perches for front axle
RennTech Digital Suspension Lowering Module (DLM) for rear axle
Lowering Range: 20-40mm Front / 45 mm Rear
Four corner height adjustability of the original suspension kit
Rear ride height can be adjusted on the fly via DLM software
OEM electronic damper control is retained
Aggressive, lowered vehicle stance
Improved vehicle handling and performance
Renntech Intercooler Pump Upgrade Kit
Click HERE to order Intercooler Pump Upgrade Kit!
RennTech latest second generation intercooler pump out performs any other unit on the market; flowing over twice as much coolant as the problematic OEM pump and significantly more than its predecessor. Testing showed our Intercooler pump Testing showed our Intercooler pump flows an impressive 8.7 G.P.M. @ 11.6 P.S.I. compared to the OEM pumps 3.00 G.P.M. flow rate. This increase in flow dramatically removes heat from the incoming air; allowing for a denser air/fuel mixture and substantially cooler charge air temperatures over the entire operating range. RennTech pump upgrade kit mounts in the OEM location without any modifications, due to its dramatically smaller size and lighter weight and comes complete with all necessary plumbing, electrical connectors, mounting hardware and installation instructions.
Features
Significantly more than its predecessor
Impressive flows 8.7 G.P.M. @ 11.6 P.S.I.
Increase in flow dramatically
Removes heat from the incoming air
Smaller size and lighter weight
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
Old Dec 17, 2019 | 02:38 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Dec 27, 2019 | 12:49 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Jan 3, 2020 | 02:24 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Jan 17, 2020 | 08:11 AM
AutoTalent's Avatar
SPONSOR
G55
Bump!
