Mercedes CLS550 Muffler Delete with Mandrel Bent Custom Exhaust Shop in Ohio
Even though some have done so without problems, I decided against deleting the center resonator (and replacing it with straight pipes) as the center resonator is really an X-pipe when you look inside it, and its purpose I believe is to equalize upstream exhaust pressures from the left and right banks of the V8 at this central location. (imagine a worst case scenario if you straight piped the x pipe resonator and one side of your exhaust was either partially or fully blocked, not allowing full exhaust flow. An entire engine bank/side would experience higher backpressure than the other side, thus not allowing that side to breathe properly and expel or intake exhaust and air equal to the other side. This would cause an imbalance in the running of the engine. An X pipe resonator is a point where exhaust flow is mixed and exhaust pressure is equalized from left to right bank, so that even if there is more restriction in one side of the exhaust piping and muffler downstream of the x pipe resonator, the upstream exhaust flow and pressures that the left and right banks of the engine experience will be equal, thus ensuring proper engine breathing and operation. The left and right side of the exhaust piping and muffler downstream of the X pipe resonator will flow a given amount of exhaust which may not be equal or symmetrical given different backpressures (due to different bends and restrictions between the sides). However the exhaust back pressures and exhaust flows that both banks of the engine experience will be balanced and equal thanks to the X pipe resonator
Meistershaft makes a mid resonator delete pipe for the CLS63 that replaces the stock X-pipe resonator, and it incorporates an X/H pipe, as can be seen in the pic with the mid pipes coming together and joining ever so slightly.
The youtube link below explains what mufflers and resonators do. I found it helpful in understanding their job and design.
MUFFLER DELETE or RESONATOR DELETE: Which One Should You Do? - Exhaust Mods!
It sounds pretty good revving it and driving away WOT at the end of the video.
Although you will get a louder exhaust sound straight piping the central X pipe resonator, I chose not to do it for the reasons stated in the opening post.
2014 Mercedes E-550 Coupe DUAL EXHAUST w/ X-Pipe & Straight Pipes!!
I went to Steves Auto Service in Cuyahoga Falls Ohio where they do Custom Mandrel Bent Exhaust systems. It is a top notch service garage. And the exhaust work was amazing. Bernie the exhaust tech did an amazing and neat job.
The mandrel bent exhaust cost the same as taking my car to a regular muffler shop that would have kinked the pipe bends down and restricted flow and reduced power.
Bernie used 409 stainless steel for the pipe, and I brought my own tips. The mandrel bending machine is atleast $50,000 a big investment for a shop, so I want to encourage car fanatics to go to them because of their excellent work and prices.
It was well worth the drive to go to Steves Auto Service.
http://steves-auto-service.com/
Attached are some pictures of the finished exhaust
