Error code P1CE700, CEL, CE crankcase wide open throttle
Old May 18, 2021 | 01:58 PM
Mssidah's Avatar
2012 MB CLS550 ( C218)
Exclamation Error code P1CE700, CEL, CE crankcase wide open throttle
Hey guys,
anyone get this error message before and was able to fix it or locate a possible cause?
Old May 18, 2021 | 02:48 PM
Roop94's Avatar
W218 Stage 2, E85
I, myself, haven't seen one on this forum, as far as I know. But going to follow this thread just for the information. Hopefully, someone can chime in with details.
Old May 18, 2021 | 04:25 PM
Mssidah's Avatar
I usually get the CEL when I floor it and the engine sucks air. This is the only extra piece of information that I have.
Old May 18, 2021 | 05:46 PM
Roop94's Avatar
W218 Stage 2, E85
Looks like you just need to find out where the air leak is. Inspect the visual parts for anything and maybe a compression test is required? And as the diagram states, check if all the clamps are tightened. A loose clamp will leak air, too. Especially the ones that go on turbo charge pipes.
That's all I can say. Rest is beyond my knowledge.
Old Feb 5, 2024 | 08:57 PM
doug5790's Avatar
'19 GLS550 Renntech Cl600, S63, Bentley Arnage, ‘21 Ram 2500 Longhorn
I have the same code with CEL. Only under hard acceleration. Did not do this before I installed Renntech tune. No other symptoms. I believe the control unit is simply seeing an increase in air flow that it doesn't understand. I am going to spray a little carb cleaner around the intake hoses, connections, etc. If there is the slightest leak, the RPM will jump slightly at the introduction of cleaner(fuel) to the intake system.
Old Jan 27, 2025 | 11:31 AM
LINDI's Avatar
S550
I have the same code after a tune.
Did you ever fix it od find out what it was I'm having the same problem after westec tune.
Old Apr 29, 2025 | 05:08 PM
dspecialistb's Avatar
'14 CLS550 , '86 420SEL
I initially got this code after my Weistec tune at the beginning of this year. I re-tightened the airbox and re-seated all the sensor connectors and have not seen the code since.
