Unknown Fault Code
Old Sep 10, 2021 | 09:56 PM
ScottCLS550's Avatar
2012 CLS550
Unknown Fault Code
Has anyone ever had an Unknown Fault Code (P014A00) after an engine diagnostic test??
Old Sep 11, 2021 | 12:39 AM
Ghostty's Avatar
2005 SL500, 2015 CLS400
What did you use to read the code?
Old Sep 11, 2021 | 10:39 AM
2012 CLS550
iScan
Old Sep 11, 2021 | 09:28 PM
Ghostty's Avatar
Sorry, what I was going to ask is about the device, did it give any more details about the code? It looks a decent device to give just an fault code number without a brief description.
Also, did you try erasing it and see if it will appear again? Is it a stored fault code or active?
Old Sep 12, 2021 | 01:09 AM
2012 CLS550
The "check engine" light had come on and stayed on for a couple of days. Then it went away without anything done. Shortly after that, the scan was done and nothing was found...only that "Unknown Fault Code". No other information was given...no other errors, no more check engine light...nothing. Just wondering what could have caused both of those. All of these events occurred in less than 10 days.
Old Sep 12, 2021 | 03:53 PM
Ghostty's Avatar
Unless it comes up again, a long list of reasons can trigger check engine light. I had same thing happening to myself, cleared the codes - been over a week - didn't come back again.
So overall i'd say just forget about it, since it didn't come back or no details available. An electric told me that the car can have fault codes without the CEL on, and drive just fine. I'd suggest to check later, next week or so, for codes again, and if none found - forget about it.
Regards
Old Sep 13, 2021 | 12:46 AM
2012 CLS550
I guess I don't really have a choice...haha. I'm just not a fan of the "unknown". Anyway, thanks for the feedback.
Old Sep 19, 2021 | 05:19 PM
cls5504matic's Avatar
C63 Vert
you prob need to hit it with star or something.
Old Sep 21, 2021 | 10:54 PM
mJstk01's Avatar
I had random check engine with the same code recently and was given below detail:
"The rich/lean switchover of oxygen sensor 2 (cylinder bank 2) is delayed"
Car drives fine otherwise...
Old Sep 21, 2021 | 11:39 PM
C63 Vert
That is post catalyst so it is likely fine. The o2 sensors are fairly cheap fwiw.
