Check engine with following codes. Please help!
Old Dec 17, 2021 | 05:45 PM
drsanket2000's Avatar
S 420
This am while leaving for work I got checl
enhine with these codes. Not sure where to start. It’s for 2007 cls550 with 95k miles. Thanks for your time
Old Dec 17, 2021 | 08:57 PM
Ghostty's Avatar
2005 SL500, 2015 CLS400
I would start with basic checking, like erase the codes and see if they come back.
The Oxygen sensor most of the time is pretty self explanatory - when it goes bad - it needs replacement and throws a code.
The other two - not so sure, but the P0025 might be related to the oxygen sensor, since they're on the same side (bank 2). You'd be surprised by how much a bad sensor might affect the engine.
Regards.
Old Dec 19, 2021 | 01:07 PM
DigitalDisaster's Avatar
2013 Weistec 540/715 tuned CLS 550, 2008 E350, and '07 Jaguar S-Type R
I agree, likely a faulty oxygen sensor.
Old Jan 24, 2022 | 05:02 PM
MB2012Cls='s Avatar
2012 CLS550 W218 M278
My C218 went into limp mode last summer, the electr radiator cooling fans go into constant on high speed and it sounds loud. I took it to the dealer and feared the worst but they reset the codes for no charge and its been fine since. I bought my own OBDII code reader and check and reset codes myself now. I noticed a couple other electric glitches with the Parktronic system so I replaced the main AGM battery and all is well now
