Best Exhaust Cutout Location?
I'm working on getting an exhaust cutout kit installed/I install on my CLS550 and don't really know the best spot to put it or what I should remove from the system. Essentially, I want it to remain as stock-sounding as possible - it's a daily driver - but sound like a bat out of hell when I want it to. I know that I probably won't achieve the best results with this, just because I'm not looking to do a full resonator/muffler delete with an X pipe, but I am curious as to what the best setup is.
My questions are below:
- The 1st set of resonators/cats on the pipes - are those 1st resonators or secondary cats? I've heard them called both, but if they're cats I don't want to touch them (VA has strict emissions standards)
- If they are resonators, would it be best to replace them with some straight pipes with the valves off of them?
- If they are cats, would I see any benefit to placing the cutouts before the resonator, if there is enough clearance?
- If the only reasonable option would be to put them after the resonator, would the difference in sound even be that noticeable?
I know my questions are a bit all over the place, but I'm really just asking what is my best option here to have the closest-to-stock sound with the valves shut and have the most aggressive sound with them open.
Thanks so much in advance!
