Air matic malfunction
Old Oct 6, 2022 | 09:13 AM
citizensane's Avatar
Merc CLS550
2014 CLS 550--80K miles
For the past few months I have been waking up to the "vehicle rising" warning upon morning start up (only)--it's become a daily occurrence. For the past couple of weeks--I've taken a yard stick and measured each tire/wheel from ground to bottom fender edge. ut 27"
The measurements have become consistent and show that after rising--all four wheels are at about 27" to 271/4" ground to fender. With the passenger side front often starts (when cold prior to first start up) can be as low as 241/4 and on a few occasions at 27" (the car doesn't go into raise mode on those rare mornings). The drivers side front is can be as low as 26 1/2" but more often is at 27"
Thus my conclusion is that the passenger side front needs a new air shock (my understanding is that this model has four "air" shocks --one at each wheel (not positive that's the case)
If I'm correct on these "air shocks"--can just one be changed out--or do both fronts need to be changed?? (or all 4?)
Any advice is appreciated
thanks!
Old Oct 6, 2022 | 11:54 AM
konigstiger's Avatar
'71 Pinto
Best to have someone pull codes using Xentry (MB diagnostics) for definitive diagnose, see function attachment. Reluctant to do so, leak test pressure lines to strut & valve unit @ compressor. If strut is failing internally given your mileage 80,000 > MB recommends replacing in pairs (front or rear). Here are MB RWD part #s to shop should also pull compatible Arnott aftermarket.
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 6, 2022 | 11:58 AM
Merc CLS550
thanks for the detailed reply! As it is just the one front strut that seems to be failing--can I get by with replacing both fronts but leaving the rears as is (wait for them to start failing)?
Not driving that much anymore--maybe 9K per year
appreciated
Old Oct 6, 2022 | 12:21 PM
'71 Pinto
Yes.
Old Oct 10, 2022 | 08:42 AM
click430's Avatar
12 CLS 550, 65 Shelby 427 SC, 03 GMC Envoy
Be advised… if you replace the front struts/bags with the more affordable Arnot units, the feel is a bit mushy, no matter the mode selected.
Not bad, just not “firm” anymore
Old Oct 10, 2022 | 09:35 AM
Merc CLS550
I'm letting my Indy guy buy the parts and pretty sure they'll be OEM. $625 each--$1200 per wheel total
thanks
