couple of unusual codes, cant find answer anywhere
Old Jan 27, 2023 | 01:54 AM
drsanket2000's Avatar
S 420
on my 2016 cls550 these are the codes and not sure if anyone here had similar experience. thanks for your time
Old Jan 27, 2023 | 10:32 AM
konigstiger's Avatar
'71 Pinto
Have you erased codes to see if they return. If they return, may be auxiliary battery - MB part 0009829608 (should also pull compatible aftermarket).
File Type: pdf
Old Jan 27, 2023 | 11:53 AM
S 420
I did try easing code but keeps coming back. do I try to charge auxiliary Battery or just replace it?
Old Jan 27, 2023 | 12:02 PM
'71 Pinto
Given your situation, depending on water damage replacement may be needed.
https://mbworld.org/forums/cls-coupe...ease-help.html
https://mbworld.org/forums/cls-coupe...sue-codes.html
Old Jan 27, 2023 | 11:31 PM
S 420
so I did replace battery and most problem got resolved but one. can someone assist?? error code is 9EA953. thank you
Old Jan 28, 2023 | 03:07 PM
'71 Pinto
You need to check for leaks to bladders (700 in diagram) and/or valve lines (750). See attachments to gain access.
File Type: pdf
File Type: pdf
File Type: pdf
