Check f151 (60A) - steering control unit @ front prefuse box If fine, long shot but pull for several minutes in an attempt to reset. No luck, steering gear motor is a common failure, MB does not offer motor separately only complete steering gear assembly but they are available need to search. Regardless, you will need dealer or independent to check it before replacing parts.
