Lowering Module
On the other hand, MBenzl Steve and Dean can use Mercedes Star system to lower the car for lot lot less. I'll do that next week and will happy to share with you after that.
https://mbworld.org/forums/e-class-w211/102782-mbenznl-lowering-module-complete-pics.html
Cheers!
Press Release, February 2005
Carlsson C-Tronic® SUSPENSION
Intelligent lowering
• Intelligent adaptation of spring travel
• Sporty look by lowering up to max. 30 mm
• Improved driving dynamics through reduced roll
• For Mercedes Benz models with Airmatic and ABC suspension
The Carlsson C-Tronic® product range includes electronic control modules for a variety of applications, such as engine control and supercharger or turbo control, as well as the control of active and semi-active suspension systems. The solution offered under the Carlsson C-Tronic® SUSPENSION brand has been improved in several important respects and thus meets the high expectations of an intelligent electronic suspension control system.
Maximum ride comfort in all situations
As a rule, conventional systems for lowering vehicles with electronic sus¬pension systems do no more than lower the centre of gravity. By contrast, the Carlsson C-Tronic® SUSPENSION lowers not only the centre of gravity but also, thanks to its sophisticated technology, reacts intelligently to the changing road conditions. On poor surfaces where the suspension jounces continuously, the vehicle height is automatically raised to ensure sufficient spring travel for even ride comfort. This demand-responsive system is controlled electronically and automatically so the driver enjoys a high level of ride comfort in all situations. The permanent data synchronisation with pre-set values ensures split-second adaptation to the road conditions prevailing.
Sufficient spring travel guaranteed at all times
The Carlsson C-Tronic® SUSPENSION also ensures that the vehicle is not further lowered at speeds of over 120 km/h as programmed in the standard system. This guarantees sufficient spring travel and that the ride height does not fall below the minimum level.
Quick and easy installation
Thanks to the tried and tested C-Tronic® connection technology for the wiring harness, installing and removing the Carlsson C-Tronic® SUSPENSION is not only reliable but quick and easy. For customers, this means only a short fitting time and, therefore, low workshop costs. Furthermore, the vehicle can be returned to its original condition at any time.
