CLS Coupe (C219) Discuss the CLS Coupe.
Speed Limiter?
Old Apr 16, 2005 | 06:43 PM
MDCLS's Avatar
Airbus
Speed Limiter?
Found this in an online CLS review.What is it?
The car is loaded with high technology gizmos. Some of them take a bit of getting used to. When I first drove the car, it refused to go faster than 6 mph (10 km/h). I had inadvertently nudged the speed limiter stalk. It took a while to figure out how to disable this.
Also after reading 3 reviews in car mags,it appears the CLS500 is quite a bit quicker than the numbers MB put out. 5.5-5.6 0-60 compared to the advertised 6.1. Doesn't mean much but still nice to see.
Old Apr 16, 2005 | 08:18 PM
HRSL1702's Avatar
MB CLS350, Obsidian Black
It's part of the cruise control system which lets you set your maximum speed (although not sure why you'd want to )
Old Apr 17, 2005 | 09:48 PM
MDCLS's Avatar
Airbus
Thanks. Didn't know you could actually govern the speed with the MB cruise control.
Old Apr 18, 2005 | 08:08 AM
ruykava's Avatar
Mercedes all the way!
yup, you certainly can. quite useful when you wana make sure you never break the speed limit. if the police pull u over u cld point at the speed limiter to show him he mz b wrong
happens when u push the cruise control stalk "inwards" towards the steering. u'll then see a number of yellow "blobs" on the speedometer showing which range of speeds you can go to. this range can be set using the onboard computer. but i think it can be deactivated by flooring the accelerator, e.g. in emergency.
