Stinky Smell from the Aircon
E-240 2000 , E-240 2001 , CLS350 2006
i had a similar problem before with my old mercedes it smell like food has been left over or maybe more like sharp smell very very terrible to smell if that is the issue then i think somthing need to be replaced in the ac system sorry i can't recall what was it but sure i did replace somthing . but if you are talking about normal mercedes ac smell which i found it in all mercedes benz for some resone then u have to deal with it :P
E63 AMG
I experience it too. If I recall correctly, it is at least in part due to the fact that Mercedes A/C can both de-humidify moist air (like any A/C) but also it can humidify dry air. Like any humidifier, you'll get that smell when you first turn it on if it has been actively adding moist air to the cabin when last used.
Airbus
You may also be growing mushrooms in the vents. ;-) Do a search for "mold smell" The stinky socks syndrome has come up a number of times. My suggestion is, take it to the service center and have them treat the system with a fungicide.
CLS-500, SL-500, BOXSTER-S
I am currently going throught the same problem, but I told my advisor it smelled like "stink feet"! It has been in twice with no fix. The dealer is going to foot the bill for a non MB covered fix ($300 +) which is to run ozone through the system for a couple of days in order to kill the mold which is the cause of this smell.
