Bluetooth phone module.
Here is the bluetooth phone module.
Very easy to install has it's show on pictures
It only works with few phone like nokia's.
I'm kind of dispointed as I though it would put adresses and would be able to have more than one phone number per name but actually no.
It only read the sim card numbers.
450€ in France
450€ in France
No Bluetooth systems work on all BT phones. There is not yet (although tere will be soon) a common standard for all BT phones. Therefore, there are some limitiation on which phones will work with a BT module. Check each of the mfg (Audi, Acura, BMW etc.) sites and you will see that this is a common issue.
I found out today that you can export phone numbers in the command system, but still no adresses.
Also it only works with bluetooth "SAP" phones witch means if you have bluetooth on your phone it doesn't mean it will be compatible.
