CLS Coupe (C219) Discuss the CLS Coupe.
Command - AMG Startup Screen
Old May 25, 2007 | 10:31 PM
SilverE430's Avatar
2006 CLS 500 Silver, AMG pkg, 2008 S550 Silver, AMG pkg, 2007 GL450, 2011 E63
Just found this out:
AMG Startup screen setup instructions
A. Turn ono the command and select CD
B. Press and hold the "5" first then press and hold "3" and "7" -- all at the same time for about 3 sec.
C. This opens a menu with keyboard choices. Scrooll down to the AMG and select.
D. Press "Back" to the main menu
E. Turn off the command
F. Turn off your car.
I already tried. and it works.
I saw this instruction on Benzwrold.org.
Have a nice weekend.
Old May 25, 2007 | 10:52 PM
LetsJet's Avatar
355 F1 Spider & ......V12 w220.176
Who cares? Your sig picture is too small........
Actually, pretty cool info....
Old May 25, 2007 | 11:28 PM
Htowncls's Avatar
CL63
LOL.. yes i would like to see that picture a little bigger too! What does the AMG startup do that the regular one doesnt?
Old May 26, 2007 | 03:10 AM
SilverE430's Avatar
ok, ok. You guys. I guess this is better then AMG sign.
http://www.not-defined.com/mt/archives/images/a4.jpg
Old May 26, 2007 | 11:13 AM
LetsJet's Avatar
Good man.........
But, what does the mod do? Give a splash screen that says AMG?
Old May 26, 2007 | 02:09 PM
j_belll's Avatar
‘23 EQS AMG
damn, shes pretty cute.
Old May 26, 2007 | 04:59 PM
CLS550's Avatar
Subway
Kind of lame if you don't got an AMG though...
Old May 26, 2007 | 05:20 PM
LetsJet's Avatar
Not if you're an AMG fan. Not the same as rebadging.
Old May 26, 2007 | 07:42 PM
Goyard's Avatar
06 SL55
Ummm. Why would anyone do this on a non AMG car?
Pretty stupid.
Old May 27, 2007 | 02:20 PM
SilverE430's Avatar
Besides point. just choices and information. man Also try button "nav" and "5". it pull out some strange options. Have a great weekends. guys.
Old May 27, 2007 | 02:59 PM
pmb600's Avatar
E550 4MATIC
I don't think there is anything wrong with this. Putting AMG logos on the outside of the car seems like one is trying to pass off their car as an AMG. If he wants to see the AMG logo on his screen for 5 seconds when he starts the car up, I don't see how that hurts anyone.
Old May 27, 2007 | 04:34 PM
BRN_CLS's Avatar
CLS 350
SilverE430- thanks a lot, u da man I wanted this long time ago but I thought that I have 2 take the car to the dealer for software or somthin.............tomorrow ill check the 2nd trick, keep 'em comin
pmb600- I totally agree with u buddy, stupid?? lame?? C'mon guys there's nothing wrong with that as unless u rebadge with to 55, 63 or 65.....its even better if u have AMG rims or spoilers
I gotta go order the ///AMG illuminated door sills from formymercedesbenz.com :smo
Old May 27, 2007 | 04:46 PM
pmb600's Avatar
E550 4MATIC
Well there's nothing wrong with AMG rims on a non-AMG either...sport package does this from the factory.
Old May 27, 2007 | 05:05 PM
konigstiger's Avatar
'71 Pinto
FYI (just in case...):
DTB P-B-82.85/437 FEB05 Erroneously changing background, keyboard functions in vehicles equipped with COMAND head unit. Repair IS NOT covered under warranty.
- Color scheme is incorrect for the model
- Head unit background images at start time do not match the correct image for the specific model
- Hard keys and soft keys not functioning correctly in all modes
If this procedure does not recover correct functionality and operation of the head unit, the head unit must be replaced:
2005 171.456, 2006 171.454/473, 2004 and later 211.026/065/070/076/082/083/265/282/283, 2006 211.056/087/256/287, and 2006 219.375/376
Turn ignition on and power on the head unit
Press and hold the key combination 5+3+7 in this sequence for about 8 seconds to access the variants menu
Scroll up or down and select correct head unit variant for the subject vehicle, press OK to confirm
Press the “Keybrd” soft key for the list of possible keyboard types
Scroll up or down and select the correct head unit Keyboard for the subject vehicle, press OK to confirm
Upon correcting the variant and keyboard settings, turn ignition off and ensure MOST and CAN asleep
Turn ignition on and check functionality of all keys on the head unit using different applications
Old May 28, 2007 | 09:28 AM
BRN_CLS's Avatar
CLS 350
konigstiger- what do u mean? is it risky wiil it effect the head unit??
Old May 28, 2007 | 11:59 AM
'71 Pinto
"If this procedure does not recover correct functionality and operation of the head unit, the head unit must be replaced."
Simply, if for any reason you experience any problems with a new setting and cannot revert back to the original setting by using the posted procedure you will need to have either an independent shop, the dealer, or an experienced person attempt to repair it at cost and if it is decided it cannot be reset the head unit will need to be replaced at cost. As stipulated repair and/or replacement is not covered by warranty. The majority of those who attempted this may have been successful with no adverse affects however, just wanted to forewarn everyone.
BTW this modification has been circulating since 2005.
Old May 29, 2007 | 05:28 AM
BRN_CLS's Avatar
CLS 350
SilverE430- the second trick (cheat) didn't work, anything new??
Old May 29, 2007 | 01:03 PM
SilverE430's Avatar
After Konigstiger's post, I am afraid your command got damaged now.
But if you are still want to know, do the search on "3-5-7".
https://mbworld.org/forums/search.php?searchid=2998638
Old May 29, 2007 | 04:27 PM
kiamcoj's Avatar
2012 CLS63
...def agree with that...off topic but who cares
Old May 29, 2007 | 04:45 PM
BRN_CLS's Avatar
CLS 350
SilverE430- this thread does not exist anymore
Old May 29, 2007 | 09:18 PM
SilverE430's Avatar
just enter "3-5-7" and search, you will find many more topic. Lots of them were posted a while ago. I just found that out.
Old May 29, 2007 | 10:40 PM
Htowncls's Avatar
CL63
I like her too.. Can we get her larger?
Old Jun 5, 2007 | 06:13 AM
yaroslav's Avatar
GL550 , CL6.3 AMG
will it work in CLS 6.3?
Old Jun 14, 2007 | 08:03 PM
AGM-GROUP's Avatar
r32r24rf4
