Brake noise
You can apply it before or after you wash your car. Hope this helpshttp://www.partsamerica.com/ProductL...egorycode=3223
1. Perform four-repeated light to medium stops, from 65 to 10 mph, to bring the rotors to temperature.
2. Perform three light stops in succession. Perform eight heavy stops, back to back, at a point just pending wheel lock, from 65 mph to about 5 mph.
3. Drive for ten minutes to create cooling airflow, without using the brakes if at all possible.
4. Perform three light stops in succession. Perform eight heavy stops, back to back, at a point just pending wheel lock, from 65 mph
to about 5 mph.
5. Drive for ten minutes to create cooling airflow, without using the brakes if at all possible.
Additional Notes:
* Metallic brake pads – Metallic pads need high temperatures to keep the pad “Bedded”. If you drive the car for a period of time without using the brakes extensively, you may need to “Bed” the pads again. This is not a problem. Simply repeat the procedure.
Sounds a bit over-the-top but this is what http://www.baer.com/technical/brakin...padbedding.php
recommends. I would just be a bit more aggressive on your braking and see what happens.
