question about logic7 and bluetooth
Does the logic7 sound system have a equalizer system where u can choose different sound settings like cinema,rock,pop or like BMWs 7band custom equalizer?
and does the voice dialing feature and phone book download supported with apple iphone.
The CLS does not have an EQ setting: it is factory programmed to a set EQ curve and you get the obvious bass/treble controls plus an on/off for logic7 surround.
The bluetooth feature depends on what year cls you are getting: if you get a 2008 and below then you need to make sure that your car has the phone system fitted as well as the optional voice control system. Even then you will need to purchase the bluetooth adapter at a price of about $400 (unless this can be worked into the lease). the bluetooth adapter in combination with VCS will allow you to voice dial numbers as well as store and voice dial names. The phone book is reportedly downloading from the latest version iphones (e.g. 2.0 and iphone 3G).
If you get a 2009 CLS then it has the new command system which comes with factory bluetooth and (a much better) voice dial system. It will dial nams and numbers and you will have the phonebook download with the same iphone versions.
