CLS Coupe (C219) Discuss the CLS Coupe.
Camber Kit on W219 CLS?
Old Apr 13, 2015 | 04:31 AM
Soldier_CLS's Avatar
08 CLS 550 w/ AMG sport package Diamond White Edition
I only did the acentric bolts in the front For the camber and the caster 2 bots for each. Not sure about the rear since mine was good even though i have 20" wheesl thats 11" wide lowered with ghostlinks. Guess some have had issues i the rear. Dont have any after pix but here a few before the camber bolts were installed....it still looked good tho. Camber wasnt that bad in the front...To each their own
Old Jan 13, 2016 | 12:44 AM
KECLS63's Avatar
2007 cls63
Cls63 alignment problems
I really need help. I have a 2007 cls63 with 66k miles. Love the car, but cannot get the alignment corrected. I have a kmac camber caster kit on it, installed by my indie mechanic, been on the frame table tested true. Less than 5k on new tires. Pulls right even on a left turn negative caster (to right turn) stretch of toll road that is a good highway.
Old Apr 10, 2016 | 12:32 PM
KECLS63's Avatar
2007 cls63
Update: I took my car to Dallas Frame and Alignment shop. They do not use digital machines to align, but align it old school method. KMAC bushings had quite a bit of movement only after about 7k miles. Called Kevin at KMAC, very responsive btw, explained the situation, he dhl'ed a complete replacement kit. I get that car back in the next day or two. See how it goes.
Old Apr 14, 2016 | 01:29 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Contacted Dallas Frame and Alignment re the steering pull/movement in bushes – pointing out what to look for re the cause.
To simply check which (or both) “thrust” arm Caster bushes that are over adjusted/need to be backed off (OEM there is already ample “positive” Caster – 10 to 12.5 degrees depending on vehicle height).
The K-MAC Camber and Caster bushes are designed so they are 2 axis/self aligning. But with “over adjustment” of the Caster bush – this can pull the control arm/wheel forward till inner Camber bush binds/loads up when control arm travels through its required suspension arc (see below diagram).
PRECISE CASTER: Capability to dial in and correctly resolve steering pull with the K-MAC bush design also improving brake and steering response
PRECISE CAMBER: Front and rear – ability to reduce costly premature edge tire wear by changing tire contact angle/increasing the wear area/improving traction. Essential if altering height, wide profile tires or simply ongoing adjustment capability for curb knock damage
