CLS Coupe (C219) Discuss the CLS Coupe.
Where to get wheel spacers
Old Jan 8, 2013 | 09:26 AM
CLS550Redline's Avatar
2009 CLS550
New to the CLS world and I just purchased a set of 20" Klass 3 piece wheels. When mounting I noticed the grease bearing cover pokes through the center of the wheel not allowing me to affix the center cap all the way so I need to add spacers. I have no idea where to get spacers, if I should run a specific kind for MB, do I need to lenghten the lug bolts and also should I run all 4 corners with spacers so offsets dont look weird having spacers in front and not in the rear. Any help is much appreciated. Thanks you!
Old Jan 8, 2013 | 04:46 PM
ydlee's Avatar
06 CLS500, 07 GL450
When trying to mount the front rim does it mount up but with a gap between the rotor hub and rim? When I mounted my hub centric rims with correct offset due to getting them powder coated the rim would did not sit flush with rotor hub until I tighten the rim down until it made contact, once the grease cap goes all the way inside of the rim.
Old Jan 9, 2013 | 10:32 PM
swiftvision's Avatar
NSX
Id like to know this info as well. I want to push my 20x10's out further in the rear.
Old Jan 9, 2013 | 10:39 PM
ydlee's Avatar
06 CLS500, 07 GL450
You need extended bolts, my oem bolts are 28mm at the shank so whatever size spacer you decide to get you add that number to the 28mm. Ex. If you put on 5mm spacers you want 33mm -35mm. And make sure the spacers are hub centric. You can get them on eBay. With same idea of length of overall bolts it applies to offset. Ex. 30mm offset with 5mm equals 25mm.
Old Jan 15, 2013 | 09:59 PM
C.R.E.A.M.'s Avatar
07 CLS550 AMG
I had the same problem, my center cap came off after I mounted the wheels. It was hitting the grease cap.
Old Jan 16, 2013 | 12:04 AM
slk55er's Avatar
2024 GLB35 AMG, 2020 S560 Coupe
And make sure that the new bolts are compatible with the wheels that you have -- MB wheels have a spherical seat for the bolts while other wheels may have a tapered seat. The TSW wheels that I have on my GLK and SL cannot use the OEM Mercedes bolts because of the different shape of the bolt seat in the wheel. (I believe from my many years of BMW ownership, that BMW uses tapered seats on their wheel bolts.)
