CLS Coupe (C219) Discuss the CLS Coupe.
Blacking out head light frame
Old Apr 21, 2013 | 12:27 AM
Bullwheel's Avatar
W219 CLS 63 AMG
I know there are a lot of topics about the blacking out of the head light frames...and recommendations of a top guy in California area...and many top shops in Europe what do some top coating, but...
...unfortunately I'm here in small Hong Kong and I do not prefer to send out the head lights!
Local shops do not reply to my mails...
Is there a DIY somewhere?
Does it need a special coating or is normal car paint good enough?
Or is there maybe a HK guy around who can help?
Any advice appreciated!
Old Apr 21, 2013 | 06:28 AM
teamspb's Avatar
Cls55
Have a look at my build thread...I have done it
Old Apr 21, 2013 | 07:04 AM
Bullwheel's Avatar
W219 CLS 63 AMG
teamspb, yes I saw your thread before...exactly what I want!
Could you tell me more?
Was it hard to remove the glass? ...did you use a heat gun?
What you used for spraying and what preparations were done before spraying?
What you used and how you sealed the head lights when assembling?
Sorry if I ask too many questions, but it is easy to ruin it and then it gets costy!
Old Apr 21, 2013 | 01:07 PM
j0r3t0's Avatar
C 220 CDI sportcoupe
I am interested about Bullwheel questions too. It will be nice if you could tell us
Old Apr 22, 2013 | 01:58 AM
mbenz1's Avatar
2007 CLS 550 and some other MBZ
Definitely search for threads posted by a forum member "khelawanb" as I remember he did that himself and he posted some pictures also. What he did to his car was amazing and he is a nice guy, so you might want to send him a message.
Old Apr 23, 2013 | 04:47 PM
teamspb's Avatar
Cls55
Yeah sure pal!
The plastic (not glass), is awkward to remove, but so are all headlights that you try to pry apart, the key is lots of heat (I used a heat gun) to soften the glue/sealant and then you need to slowly pry the plastic from the backing...it does require lots of patience and a few prying tools - screw drivers etc.
Also dont forget to remove the metal clips around the headlight first!
I used Plasti-dip as it requires no prep work and I had lots left over from my grill. If you are using normal paint, just rub down the housings, then prime, then sand, then paint black/colour of your choice.
I used a product called Tiger Seal to bond the lights back together, and im happy to report there is no misting in the headlights!
Old Apr 23, 2013 | 09:30 PM
Bullwheel's Avatar
W219 CLS 63 AMG
@teamspb: Thanks for the info...!
Old Apr 23, 2013 | 11:21 PM
jaedee's Avatar
w205 C63s, w212 E63,w219CLS500-SOLD! w211 E63, 2006 E60 M5 (KABOOM!)
The hardest part of this mod is removing the housings from the car. You remove the bumper to get them out. I put mine, one at a time (after removing all the metal clips and bulbs) in the oven for 12 minutes at 225 degrees Fahrenheit. The housing then pulls right apart with your hands. Remove the chrome part and clean with wax/grease remover. Use the paint of your choice. I paint cars as a hobby, so I chose to use bullydog adhesion promoter for plastic, primed them and then painted them satin black. (I have seen these done with Krylon Fusion paint with good results also) Once the paint dried, I stuck them loosely together (the OEM adhesive stays tacky) and threw them back in the oven for 10 minutes. Pushed them back together (only using the original OEM sealant) and reinstalled the clips and bulbs. No condensation issues. Looks like this:
Old Apr 30, 2013 | 12:43 PM
CLSED550's Avatar
CLS, Grand Cherokee, Range Rover HSE, 70 cuda 440+6
Good job . Looks good
