CLS Coupe (C219) Discuss the CLS Coupe.
Would these fit a W219 - 20x11 et35
Old Jun 11, 2013 | 12:50 AM
95viper's Avatar
2007 cls550
Would these fit? I assume rear spacer?
20 x 9 et25
20 x 11 et35
255-30-20 and 305-25-20
Old Jun 18, 2013 | 05:05 AM
teamspb's Avatar
Cls55
They will go on...I run 10.5s on the rear of mine with an offset of et17 and as I run mine low, cant get a wider tyre on it than a 255/35
Im assuming you run near stock height in which case you should be ok
Old Jun 18, 2013 | 09:18 AM
95viper's Avatar
2007 cls550
Wow..et17 is low, even with 10.5.
What has me confused is how these were on a 2012 CLS. It's a 20x9 et35 and his OEM et is 47 if I recall. Our OEM et is 28.
So he is pushing his out 12mm and I would have been going in 7mm. Confusing.
Lakehouse is checking his et's on 20" rims that he installed to get a comparison because he isn't running spacers.
Old Jun 18, 2013 | 10:17 AM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
it will fit
Old Jun 20, 2013 | 10:42 PM
CLSED550's Avatar
CLS, Grand Cherokee, Range Rover HSE, 70 cuda 440+6
Et35 / 11" wide will not fit . It WILL rub the inside plastic . Try it.. You will need a 10mm spacer or 15mm spacer . No big deal.
