CLS Coupe (C219) Discuss the CLS Coupe.
Cup Holder removal?
Old Oct 4, 2013 | 04:18 PM
bodytech's Avatar
CLS550 AMG
Cup Holder removal?
How do I remove the center console to get to the back screws for the cup holder? I can get the shifter console out with no issues.
Old Oct 4, 2013 | 05:15 PM
konigstiger's Avatar
'71 Pinto
http://ww2.justanswer.com/uploads/eu...e_paneling.pdf
Attachment covers exposed cup holder
File Type: pdf
Old Oct 8, 2013 | 01:54 PM
swiftvision's Avatar
NSX
What is the part number for the grey cup holder? Can you buy just the center insert? Typical chrome rings are getting fugly.
Old Mar 9, 2014 | 01:45 AM
bigz1969's Avatar
2009 CLS
The chrome ring pull off pretty easily. It sound weird but if you soak them in regular bleach the chrome will dissolve. I ended up painting them with HOK paint and they turned out great. Beat buying a new cup holder from the stealership.
Old Mar 9, 2014 | 04:56 PM
Cjackermann's Avatar
2007 CLS550
those are the wrong directions for the CLS550 W219. my cupholders are open and have the little button in the middle. i cant get the center console off either
Old Mar 10, 2014 | 06:38 AM
dirtydog's Avatar
2006 CLS500
I have the open one too. If you hold the button in the center and lift up on the part with the chrome it will pull right out. I just swapped that part when mine started chipping but unfortunately I had to purchase the whole part. No big deal I just swapped the part I needed.
Hope this helps.
Old Mar 11, 2014 | 10:45 AM
2007 CLS550
its not the chrome i want to replace. its the actual whole assembly. the spring loaded part does not work, i have scoured the internet and keep coming up with the same document posted above which is not correct for removing the center console to get to the screw on my W219
