CLS Coupe (C219) Discuss the CLS Coupe.
MISSING A BOLT/BUSHING? REAR AXLE
Old Feb 14, 2014 | 11:33 AM
Night-Rida's Avatar
2007 CLS550 W/AMG SPORT PACKAGE
Hello, I just got done looking under the rear of my car and noticed what looks to be a missing bolt/bushing. there are two holes at rear/center of rear axle. right side is empty and can see a threaded hole. Does anyone know if this is normal or do I need to get a replacement bolt? Thanks
Attached Thumbnails MISSING A BOLT/BUSHING? REAR AXLE-20140214_111536.jpg   MISSING A BOLT/BUSHING? REAR AXLE-20140214_111540.jpg
Old Feb 15, 2014 | 05:20 AM
Cjackermann's Avatar
2007 CLS550
Normal.
Old Feb 15, 2014 | 07:37 PM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
+1
Old Feb 16, 2014 | 12:50 AM
Night-Rida's Avatar
Thanks.
Old Aug 13, 2018 | 02:53 PM
LexBrett2's Avatar
2007 Mercedes E550
I have the same issue and I find it hard to believe that this is *normal*? Does anyone have a parts diagram to verify? I have been looking for hours...
How can this be normal?
Old Aug 17, 2018 | 09:34 AM
LexBrett2's Avatar
2007 Mercedes E550
Progress!
I believe I have finally tracked down the potentially missing part number.
The bushing part number is 2113511142, and can be seen at this website which indicated TWO are required:
https://spareto.com/products/21765-mounting-transfer-gear
It is attached to the rear suspension crossmember which is part number 2113507508:
https://mercedespartscenter.com/parts/2006/Mercedes-Benz/CLS500/Base/?siteid=215720&vehicleid=186268&diagram=5720675&di agramCallOut=11
The crossmember is part number 1 and the suspect bushing is number 5.
The question remains whether or not TWO or ONE bushing are required?Progress!
Old Aug 20, 2018 | 12:01 AM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
Would suggest calling a dealer if you don’t have a WIS.
Old May 20, 2019 | 09:23 PM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Same here. Have a look. This is 2007 E320 Bluetec. Nuts!
Old May 21, 2019 | 08:32 AM
LexBrett2's Avatar
2007 Mercedes E550
so wierd
Old Feb 9, 2020 | 12:52 PM
Mark 2010CLS550's Avatar
I have owned a 2010 CLS550 since 2014.
I am finding the same empty mounting hole on my 2010 CLS550, so I guess that is just like that by design - very strange for a high stress drivetrain location - maybe that is why my diff is whining at only 85k!!!
Old Feb 9, 2020 | 01:58 PM
konigstiger's Avatar
'71 Pinto
MB EPC shows normal by design however, cls63 shows 20MM grommet cover part # 0039975586 (35 in diagram) replaced by current 0039981450. Apparently grommet is a multi-purpose part.
Old Aug 14, 2024 | 03:24 PM
mborrero's Avatar
2006 CLS 500,4dr
Red face
Originally Posted by LexBrett2
Progress!
https://spareto.com/products/21765-m...-transfer-gear
https://mercedespartscenter.com/part...gramCallOut=11
Mine looks the same and I THOUGHT a bolt was missing. Apparently not. Can anyone confirm?
thank you,
manuel
Old Aug 14, 2024 | 03:33 PM
mborrero's Avatar
2006 CLS 500,4dr
Apparently, there is no bolt in that location. Can anyone confirm?
Thank you.
Manuel
Where do you recommend for ordering parts for my CLS500?
Old Aug 15, 2024 | 12:51 AM
mborrero's Avatar
2006 CLS 500,4dr
Manuel
I am missing the same bushing/bolt on the right rear differential. Is it normal to have only one bolt?
