CLS Coupe (C219) Discuss the CLS Coupe.
Clock problem need help! w211/w219
Old Mar 13, 2017 | 04:34 PM
ononator's Avatar
mercedes cls550 w219
Hi,
I have a 2008 cls550 and my analog clock in my instrument cluster stops working everytime I shut down the vehicle.
When I reenter my vehicle and turn the key the clock syncs again with the digital clock in my comand, but when I park my car the clock stops again.
I already tried resetting the clock (by removing the fuse) . The clock succesfully resets but the problem remains.
Is there anybody whon knows a solution?
many thanks!
Old Mar 15, 2017 | 01:57 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to C219 forum...
Old May 11, 2019 | 06:56 PM
paulkol's Avatar
ml320
..my analog clock stopped period and i don't know which fuse controls it..mine is a 2012 s350
Old May 12, 2019 | 11:15 AM
konigstiger's Avatar
'71 Pinto
Try resetting in COMAND.
File Type: pdf
Old May 12, 2019 | 12:07 PM
'71 Pinto
You can check F40 @ front SAM (engine compartment) to UCP that provides ultimately power to clock (no dedicated fuse) but you may need to replace clock. If this is the case you have the choice of replacing complete center nozzle panel inclusive of clock used or disassembling current panel to replace stand alone clock. I believe the center air vent panel is part 2218300554, need VIN to confirm. BTW you should be posting here: https://mbworld.org/forums/s-class-w221-74/
Old May 21, 2019 | 05:43 PM
paulkol's Avatar
ml320
thanx..will follow up
Old May 23, 2019 | 10:26 AM
paulkol's Avatar
ml320
..tried command reset...no dice....gave up....then today i got into my car and noticed the clock moved ahead 15 minutes but is still not running...WHAT GIVES!!
