CLS Coupe (C219) Discuss the CLS Coupe.
Boot lid and number plate lights problem
Old Oct 12, 2017 | 02:34 PM
clster's Avatar
CLS350 CGI
I have 2008 CLS 350 that I have driven för about 2 weeks now. When I bought the car the right numberplate light was not working. Today I decided to change that light bulb but came into some problems. I unscrewed the light and changed in the screwed it back. Both lights now work fine. But, the car claimed that none of them worked when I started the car. That the first issue, is there any way to reset it or something that I might have missed that I must do? I don't have the owner manual so I could look anything up there.
The second problem that came at the same time is the boot lit. Half way through unscrewing I opened the automatic boot lid to see if I could reach the screw better that way, but the boot lid stopped like 1/4 of the way or something. It wont open any further or close by it self. Nothing happens if I press the closing button, unless I manually push the boot all the way up, then the boot goes down to the same 1/4-ish position. So I have to manually close it as well?. How can I reset this?
Old Oct 14, 2017 | 04:36 PM
konigstiger's Avatar
'71 Pinto
Check wiring harness running along left trunk hinge.
Old Oct 20, 2017 | 09:50 AM
clster's Avatar
CLS350 CGI
Checked the harness and 2 of the wires were completely off. Which probably caused both electrical problem with the trunk aswell as the false warning on the lights. Both are now solved. Thanks
Old Oct 24, 2017 | 09:48 PM
Mike4671's Avatar
09 cls550
Wiring in trunk
I had same problem and ended up replacing all the wires in the trunk
