Aircon climate control question
When i shut down the vehicle and lock it these lights still remain on. Now im not sure if its a feature of the vehicle or an option in the hidden settings that i accidentally enabled. But looking for a solution or a rest procedure to make them turn off when the vehicle is switched off and locked. All other dash lights turn off normally.
Vehicle is an 05/06 Cls500.
Any assistance or suggestions greatly appreciated.
Just a follow up to this issue. Solution is as follows this worked for me. Disconnected the negative battery terminal for 5mins reconnected and all good. Background aircon lights remained off when i re attached the terminal. Hope this helps someone else if they run into this issue.
