Metal shavings in tranny pan.
Tranny fluid in connector.
Magnet with metal sludge.
Ok i took off the tranny pan to my 06 cls and about 5 quarts of super black fluid came out. Symptoms are no movement when shifted into drive or reverse. So, my question is, are these metal shavings in the pic a major concern i.e new transmission concern? Also, the plug also had some tranny fluid in it. What do you guys think?
Also did the situation improve when you changed your fluid and filter? How many miles do you have? Have you checked for codes? On my previous car which was a 722.6 transmission, I had a hard shift when I downshifted from 2nd to 1rst. I used a bottle of seafoam transtune and flushed the fluid, and my situation was completely solved. I also had think black sludge on the magnet. My theory is that over time the valves got sticky causing the hard shift. I will be doing a fluid change next month on my class, which has 67k miles..
First thing I would do is study the codes and investigate what others have done.
Then most likely I would clean the connector and do a complete fluid and filter change.
Last I would reset the battery, start her up, and hope for the best!
