Dear Friends, My upper ball joint in the front of my w219 on the passenger side is making a terrible noise and believe the upper ball joint is failing. Do you all know the torque specs for these bolts? I believe the center nut is 60nm, but not sure about the other three (see pics below)? Thank you very much in advance and have great day!
DO you all know the specs for these bolts?
The ball joint in this pic is making a terrible sound and I am replacing. The main bolt holds the assembly together, along with three bolts that attach the upper control arm.
