CLS Coupe (C219) Discuss the CLS Coupe.
What is this?! Empty mount is normal?
Old Aug 13, 2018 | 08:27 AM
LexBrett2's Avatar
2007 Mercedes E550
Last night I checked my differential and couldn't believe what I saw! The rear plate with two bushings had the right bushing missing. I could even see the threads. What do you all think? Note, I had been hearing a sound every time i let off the throttle so suspected the differential.
Note: The bottom caption should read \"Right side is differential with bushing missing".
Right side bushing gone and can see threads
Left side has bushing, right is empty and visible threads
Just a pic of differential
LexBrett2 , Today 07:24 AM
I am reading that this is normal but I find it hard to believe: https://mbworld.org/forums/cls-coupe-c219/531055-missing-bolt-bushing-rear-axle.html
Old Aug 13, 2018 | 08:54 AM
LexBrett2's Avatar
2007 Mercedes E550
Is it somewhere in this part diagram? Maybe number 5? https://www.mbpartsus.com/a/Mercedes-Benz_2006_CLS500-Base/_53894_5982006/AXLE--DIFFERENTIAL/5720675.html
Old Aug 17, 2018 | 09:35 AM
LexBrett2's Avatar
2007 Mercedes E550
Progress!
I believe I have finally tracked down the potentially missing part number.
The bushing part number is 2113511142, and can be seen at this website which indicated TWO are required:
https://spareto.com/products/21765-mounting-transfer-gear
It is attached to the rear suspension crossmember which is part number 2113507508:
https://mercedespartscenter.com/parts/2006/Mercedes-Benz/CLS500/Base/?siteid=215720&vehicleid=186268&diagram=5720675&di agramCallOut=11
The crossmember is part number 1 and the suspect bushing is number 5.
The question remains whether or not TWO or ONE bushing are required?
Old Aug 17, 2018 | 01:21 PM
konigstiger's Avatar
'71 Pinto
See EPC attachments to identify part and quantity.
File Type: pdf
File Type: pdf
