CLS Coupe (C219) Discuss the CLS Coupe.
Extended Warranty on SBC Brakes for real?
Old Jul 18, 2019 | 06:44 PM
lna's Avatar
lna
E320CDI 2006; GL550 2008
Thanks, konigstiger.
I'm in Canada. Wondering if this Addendum apply to Canada.
Old Sep 22, 2019 | 08:45 PM
Hotkeys's Avatar
2003 E500
I called them just out of curiosity for my car (2003 E500) and they confirmed it was covered 25/Unlimited. He had to call me back a few days after my initial call because he said he hadn’t heard of it.
Old Jan 10, 2020 | 08:44 PM
cosmictrucker's Avatar
2015 S550 4matic / 2003 E55 AMG
Well, after letting my 03 E55 sit for about six months after the purchase of my 15 S550, I had the need to move the car. It's been on a battery tender, so cranking wasn't a problem, but the engine had trouble starting. I'm thinking the gas has gone bad sitting this long. While cranking to get the car started, the brake red warning popped up. The car did start, but then I couldn't move the shifter from park. I had to shut the engine down, turn the key back to on, then I was able to move the shifter to neutral, start the engine, then move the shifter to reverse. This worked and right after moving the car out of the driveway all of the warning lights went out and the car drove fine. I drove the car around that day without any further issues. Today, after about a week of the car sitting, the very same issue once again. I can hear the SBC pump running, and it cycles three times before it stops. I'm guessing this pump has finally weakened to the point it can't build the correct pressures. I'm hopeful my local dealer is able to warranty this repair without too much hassle.
