CLS Coupe (C219) Discuss the CLS Coupe.
Airmatic relief valve
Old Feb 7, 2019 | 08:26 AM
panam93's Avatar
CLS 500 w219
Hello, after replacing the two shocks before I have a problem on the front left shock. I can not lower it, I use a sd connect 5 to set the airmatic.
When I try to go down the front left, I hear the contacts of the shock and the relief valve only works for one second and stops before it can work it must activate another damper and then it can be triggered on the left front but just for a second and it hangs. The right front normally works up or down.
I reversed the level sensors, I tested another pneumatic valve block, I tested another airmatic module, I changed the compressor filter.
