Airmatic Malfunction Visit Workshop CODE 5508 Pressure Line Leaks
Does Anyone had this before i rebuild my compressor that was weaken from years before and everything was fine few days maybe week no malfunctions and error codes after i washed my car one night i got white indicator on my dashboard car does not sagging and sinking overnight when i lock car goes down also when i unlock pressure comes in struts does have anyone who got problem like this solved
Received 4,445 Likes
'71 Pinto
No leaks, I agree weak compressor. Pressure is not building quick enough to satisfy system. Also, for peace of mind check compressor electrical harness connector/connection.
Anonimi (10-18-2019)
Dear
so no when i restart car does not come back maybe whole day
Check for errors and post it here. Had a lot of situations with AIRMATIC, you can`t have an answer without a code (can be compressor or struts, or even the valve). If you find someone with STAR, you can check the pressure, the valves, the air struts, just to be sure
