AutoTalent | Renntech Ecu + Suspension + Transmission For Mercedes-benz CLS 500
Subscribe
Dec 9, 2019 | 12:08 PM
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and Driver Reliability
Significant Gains in Horsepower
Increases the Performance
Significant Gains Torque
Increasing the Engine's Rev Limiter
Incredible Performance Gains
Stock Performance
302 HP @ 5600 RPM; 339 LB-FT @ 2700-4250 RPM
Modified Performance
320 HP @ 5600 RPM; 355 LB-FT @ 3000-4600 RPM
Renntech Carbon Fiber Flat Top Airbox
Click HERE to order Carbon Fiber Flat Top Airbox!
RennTech Carbon fiber air box for the Mercedes V8 engine (M113/112). RennTech full carbon fiber airbox is more than just an impressive under the hood showpiece. By allowing a greater volume of intake charge air; our carbon airbox upgrade allows for greater horsepower and torque across the entire RPM range. The result is an additional 10 HP and 10 Lb/ft with increased throttle response and improved drivability.
Features
High quality prepreg carbon fiber construction finished
Greater horsepower
Greater torque
Gain 10 HP and 10 Lb/ft
High quality material used
Stunning good looks
Improved drivability
Renntech Exhaust Stainless Steel Headers
Click HERE to order Exhaust Stainless Steel Headers!
RennTech stainless steel and ceramic-coated exhaust headers offer true bolt-on installation, mounting directly to the OE down pipes and all RennTech headers are hand built from mandrel-bent, seamless tubing and CNC machined stainless flanges. Advanced computer aided design (CAD) and flow-analysis software allows RennTech headers to deliver substantial gains across the entire RPM range. RennTech headers are constructed of the highest quality T-304 stainless steel and are ceramic coated to further reduce latent heat in the engine compartment as well as combat against thermal stress.
Features
Highest quality T-304 stainless steel exhaust headers
Reduce latent heat in the engine compartment
Ceramic-coated exhaust headers
High quality meterials used
Looking more aggressive
Design is perfect
Simple to install
Gain +15HP & 20TQ
Renntech R1 Performance Package
Click HERE to order Performance Package!
The RennTech R1 Performance Package is the perfect entry level performance upgrade for the CLS. The R1 performance package for the Mercedes 500 series engine includes our proprietary ECU upgrade in addition to our full carbon fiber airbox upgrade which offers a larger volume of incoming air for better engine breathing and improved cylinder filling. The R1 performance package provides noticeable increases horsepower, torque and throttle response across the vehicles entire powerband while still maintaining daily driver reliability. The addition of the upgradation helps the engine to perform well and better.
Features
Up to 325HP and 365 TQ
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increases horsepower
Increases throttle response
Increasing the engine's rev limiter
Incredible performance gains
RennTech ECU Upgrade
RennTech Full Carbon Fiber Airbox
Stock Performance
302 Hp @ 5600 Rpm; 339 Lb-ft @ 2700-4250 Rpm
325 Hp @ 5600 Rpm; 365 Lb-ft @ 3000-4600 Rpm
Renntech V3 Digital Suspension Lowering Module
Click HERE to order V3 DSLM!
The RennTech V3 Digital Lowering Module (DLM) is designed to work with all available Mercedes Airmatic or ABC (Hydraulic) Suspensions.The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments. The DLM requires no splicing or soldering to the factory wiring harness. The RennTech harness utilizes the factory pins as to allow a completely reversible installation. The unit also supports speed-dependant lowering that allows the vehicle to return to its factory ride-height at a pre-set speed. This removes the need for the vehicle to be aligned after lowering. The user can maintain the factory longevity and still have the lowered look at low speeds. All RennTech DLMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently.The software also has three locations where the user can store pre-configured suspension setups for quick changes.
Features
Current Consumption: 30mA (60mA while plugged in to PC/Tablet)
Adjustment increments: 1mm
Maximum Lowering: Limited only by vehicle
Adjustment Methods: PC or Android (Tablet)
Size: 53mm x 73mm x 24mm
Weight: 1.2oz
Renntech Suspension Toe Link Kit
Click HERE to order Suspension Toe Link Kit!
Adding a RennTech toe link kit maintains stability at high speed, ensures the vehicle tracks straight under heavy acceleration as well as properly positions the car's suspension under heavy cornering and braking loads. When used with our adjustable camber bushings, the high-quality aircraft grade materials used in the toe links kit result in a "total package" solution that improves handling without negatively impacting ride quality and comfort. The RennTech toe link kit also allows the possibility of fine adjustments to the suspension and of bump steering for additional stability and improved vehicle handling characteristics.
Features
Ensures the vehicle tracks.
Maintains stability at high speed
Improves handling by total package method
I possibility of fine adjustments to the suspension
Renntech Rear Camber Bushing Kit
Click HERE to order Camber Bushing Kit!
RennTech fully adjustable rear camber bushing kit allows for a greater range of rear camber adjustment. This ensures proper suspension alignment to maximize perfomance and handling under all driving conditions and and is the companion component to our adjustable toe link kit which is required. RennTech's kits ensure proper suspension alignment to maximize perfomance and handling under all driving conditions and and is the companion component to their adjustable toe link kit which is required.When used with RennTech's toe link it, the high-quality aircraft grade materials used in the toe links kit result in a "total package" solution that improves handling without negatively impacting ride quality and comfort.
Features
High-quality aircraft grade materials used
Proper suspension alignment
Rear camber adjustment
Maximize performance
Maximize Handling
Renntech Performance Brake Package
Click HERE to order Brake Package 1!
Click HERE to order Brake Package 4!
Click HERE to order Rear Brake Package!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
Deliver more consistent brake pedal feel
Improves vehicles responsiveness
Reduce fade compared to stock
High-performance brake pads
Improved performance
Long-lasting reliability
Braided steel lines
Renntech Five Speed Transmission Upgrade
Click HERE to order Five Speed Transmission Upgrade!
With increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. Renntech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech transmission upgrade consists of a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings, electrical connectors as well as a new transmission pan filter. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Maximum power is transmitted to the drive wheels
Consists of a mechanical upgrade
Mechanical upgrade to the transmission clutch packs
Improved shift response
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
Reply 0
Subscribe
Currently Active Users (1)
