CLS Coupe (C219) Discuss the CLS Coupe.
Electrical problem
Old Sep 19, 2022 | 10:03 AM
stille's Avatar
CLS 320
Electrical problem
Hi
I bought a CLS (CLS 320 CDI (219.322) year 2006 engine OM642) that not riding for a long time and after starting it turned out that there was a problem with the electrics.
I have changed new main battery because previous was empty and I realized that:
- direction indicators and emergency lights do not work
- electric seats do not work - central locking does not work
- red alarm battery is on
- strange but the registration backlight is on all the time
- and more
The first thing I thought and what they write on the forums is that the additional battery is a replacement, but interestingly in my model there is NO additional battery.
I checked all the fuses with the meter - they are OK.
HELP
Old Sep 20, 2022 | 07:53 AM
stille's Avatar
CLS 320
how to do it ? Could you explain?
Old Sep 26, 2022 | 10:22 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
1-- Can you measure the battery voltage with engine stopped as well as with engine running?
I am guessing the charge voltage is not reaching battery...
2-- Are you able to fully charge your battery with a smart charger such as CTEK?
3-- Scan the car for faults with a scanner!!
You won't get lucky swaping parts without reading what the car has to say...
You're going to find out that SAMs are used to switch circuit power.
Old Sep 27, 2022 | 06:17 AM
Constant.12's Avatar
gls c63 E300
Could it be a problem with your new battery?
Old Apr 9, 2023 | 03:46 PM
stille's Avatar
CLS 320
I have found root cause of this case - rear comfort module/computer . I have replaced it and know is OK.
Old Apr 11, 2023 | 01:03 AM
R-SAM: guilty!
Congratulations ! Enjoy your ownership now 👏
Always glad to help with many other contributors.
NEVER LET YOUR BATTERY GET LOW if conveniently possible. Keyword CTEK or similar ✌️
