Hello. I have a 2006 CLS500 and I have a doubt with the connection cables that go into the ignition module. Please refer to the photos. There are three slots in the back of the switch, and one at the side. I have matching connectors for the top (6 small pins), middle (5 larger pins), and the one in the side. There is one 6 pin connector at the bottom (similar to the one at the top but with a different pattern for the connector) for which there are no connectors present in the connector bundles in that area. As a matter of fact, I was changing the evaporator and one thing I did not disassemble was the ignition switch (I left it alone in the cover). Now the car won't start and I am not sure if I am missing something or if there never was a connector in that position.
