CLS Coupe (C219) Discuss the CLS Coupe.
07 CLS550 Instrument Cluster Backlight NOT illuminating
Old Aug 10, 2023 | 02:34 AM
eurostep's Avatar
2007 Mercedes Benz CLS550
W219 CLS550
The backlight for the tachometer, speedometer and clock which would display the numbers isn’t illuminating however, the needle/pointer lights are working.
-(Bare with me on this) Looked at a different forum that suggested I open up the dashboard and check the conductor flap for the light connection via the circuit board for a blocked conduction due to the adhesive melting overtime in hotter regions
-I’ve tried replacing the entire dashboard and installed in a refurbished one..No luck
The refurbished dashboard wouldn’t display the car miles showing ———— (maybe needed programming) Put the old one right back..
-I’ve also tried looking for a fuse and both instrument cluster related fuses were fine.
-Looked through the entire car setting interface and couldn’t find anything related
I’ve had this semi-problem from the day I bought this car and still can’t get to the bottom of it. PLEASE HELP
Attached Thumbnails 07 CLS550 Instrument Cluster Backlight NOT illuminating-b470359d-25a3-4339-9e06-dc9be65175b9.jpeg
Old Oct 20, 2024 | 05:00 PM
Moetic90's Avatar
Originally Posted by eurostep
W219 CLS550
where is the fuse location for the instrument cluster? And how many are there? 2007 cls550
Old Jul 18, 2025 | 09:42 AM
Njenjo's Avatar
W219 CLS550
have you found a solution to this yet?
