CLS Coupe (C219) Discuss the CLS Coupe.
Need some help. Lighting issues
Old Nov 24, 2025 | 02:31 PM
Cburns28's Avatar
2009 cls 550
I have a 2009 cls 550 and the issue at hand is when I turn off the car's the lower left fog/driving light stays on.. after a minute or so the low beam comes on and stays on.. the light switch is on auto or the off position and it appears that there is a relay stuck on or the front SAM module.is semdimg.power after shut down to the left side front only... any helpful hints... if it is a front SAM does it need to be coded/programmed o the car or will a salvage yard replacement be a direct plug in.. I have seen conflicting info and was hoping for a short term and long term solution.. thanks in advance
Anybody?
