CLS Coupe (C257) Discuss the CLS Coupe
CLS 2020 Brake squeal sound
Old Nov 23, 2021 | 04:46 AM
humamk's Avatar
E200 2011
Angry CLS 2020 Brake squeal sound
Hello everybody, I have a CLS 2020 and recently being hearing these brake squeal sounds, I made a visit to MB dealer, the maintenance engineer told me that ever since MB removed a cancerous material in brake pads, these sounds appeared and have no solution other than lubricants. I'm really shocked that such a brand and model facing thos issue without any solutions.
Old Dec 4, 2022 | 07:45 PM
papashango's Avatar
This and that.
This is nothing new and lots of high performance brakes do this. Audi is very prone to this. It is ****ty but the price of having high performance brakes.
Old Oct 14, 2024 | 02:23 PM
Snoopymac's Avatar
Mercedes E350 w212
I thought maybe suspension or faulty ABS?
Thank you for the suggestion but I feel it's more so an electric relay or alike sound rather than brake pads making the sound. I thought maybe suspension or faulty ABS?
Old Oct 14, 2024 | 03:17 PM
TimC300's Avatar
What did they do while the car was there, did they fix the noise?
I dont know what type of materials a CLS brake system has. I have just regular rotors and semi-metallic pads and I never hear any noise at all, installed them myself all around the car a few years ago, they are well worn in, maybe due for replacement in another year. I put around 7,000 miles/yr on it.
The maintenance guy may be right, in that the brakes should be serviced and greased. At least once a year I will remove and thoroughly clean everything, but I actually enjoy working on the car. The first time I worked on and replaced the rear pads and rotors I greased everything in there, but then was actually hearing noises like squeeks. I came across some info about where to only apply grease, went back and cleaned everything and started over. Since then they have been completely quiet.
In general I do not believe in just ignoring noises.
Old Oct 17, 2024 | 04:45 PM
Snoopymac's Avatar
Mercedes E350 w212
OK guys,
In my opinion (for what it's worth) it's nothing to do with the brakes (pads etc) I'm hearing the sound like a mobile phone vibrate. I hear it anywhere between 5 and 15 mph mainly when slowing down naturally without braking. It maybe making the sound at higher speeds but it's a very faint sound which could being drowned out by the increased road noise.
Maybe something to do with the suspension ?
