Reduced Power After Hitting rev limiter
Old Oct 17, 2016 | 07:31 PM
redbull43's Avatar
2016 AMG GTS
During spirited driving and when close or on rev limiter, once reached the vehicle kicks off boost and from there on forward regardless of what driving mode the vehicle is in the car goes into a reduced power mode. There are no warning lights on the dash or any messages of any kind, but it requires shutting the vehicle off and restarting it in order to revert back to normal. Anyone experienced this issue?
Old Oct 18, 2016 | 12:20 PM
JSwan724's Avatar
2024 AMG G63 2025 Ferrari SF90 AF Spider
SUGGESTION: Take the car back to the dealer. More than likely you need a software upgrade. They will be able to see if any codes were trapped and fix the issues.
QUESTIONS:
1. What is your Manufacture Date (on your drivers door)
2. Have had the car into the dealer for service recently?
Regards
Old Oct 18, 2016 | 02:51 PM
Vic55's Avatar
Administrator
I experienced that AFTER I tuned my car (beta testing a tune) and it was due to the TQ limits of the ECU being exceeded. It almost always happened when I was in Auto Mode, Sport Plus, and my acceleration caused the gear to drop from 7 to 4. This bumped the TQ way over threshold (tuned of course) and it would go into limp mode. I would get a CEL light though and then when I brought it back to the tuner, they adjusted to limits accordingly with zero current issues.
Old Oct 19, 2016 | 05:02 AM
SL55K's Avatar
AMG
I have the same issue in my GTS
I wont state the tuner name because they were nice enough to ask me to do a series of tests with the Benz dealer here in Bahrain, hopefully they have found the issue. Sending my ECU this week to them so they can have the issue solved.
It happens quite regularly to me, car can be any mode, after a good beating the turbos stop working, have to restart the car and all goes back to normal until i floor it again
Old Nov 5, 2016 | 04:54 PM
MStach's Avatar
2004 911 gt3
I got no cel or any dash msg .
No boost, zero
Old Nov 5, 2016 | 05:59 PM
JSwan724's Avatar
No boost, zero
BUT is your car tuned by someone other than MB??
Either way the issue may be with the tune flashed to your ECU.
They or MB may need to "adjust" the parameters.
Regards.
